Sponsored by: CARiD
Lowering C8 before tracking it
Old Jun 20, 2024 | 10:29 AM
Chuck2012GS's Avatar
Chuck2012GS
Default Lowering C8 before tracking it
Hi Guys, I am preparing my C8 Z51 MAG ride, for the track. I lowered it about 1in. One C8 owners told me he went to Ron Fellows driving school, and they were instructed not to lower the car, if you are going to track it, it’s ready to go, out of the box. Is this true, has anyone lowers their car and tracked it??
Before I spend $300 on a track alignment, I want to make sure, lowering the car, is ok.
thank you in ad
My car lowered with 19x315s in rear and 18 265s in the front installed
vance
Old Jun 21, 2024 | 08:36 AM
mikegr's Avatar
mikegr
My car is lowered about an inch on MCS 2 ways and track it all the time, runs great.
Old Jun 21, 2024 | 10:19 AM
Chuck2012GS
thank you, I did not think there should be an issue
Old Jun 21, 2024 | 02:17 PM
CAINCA's Avatar
CAINCA
FWIW:I thought that I read somewhere that the front shocks are not height adjustable if you have mag ride.
Old Jun 21, 2024 | 02:19 PM
mikegr's Avatar
mikegr
front are only not adjustable with mag ride if you have front lift.
Old Jun 21, 2024 | 02:59 PM
Chuck2012GS
correct, was no problem, with front lift you have to remove strut and put in a lowering collar and
Old Jun 21, 2024 | 03:25 PM
X25's Avatar
X25
Sr.Random input generator
We should note here that MCS coilovers are A LOT stiffer than the stock shocks, and it would be able to handle that 1" drop much more gracefully.
If you do have stock suspension, however, you might want to keep it very close to stock in ride height. The magna ride depends on the high stroke to work properly, and you might even run into clearance and/or rubbing issues if you lower it too much.
Old Jun 21, 2024 | 04:20 PM
mikegr's Avatar
mikegr
good point, I would have assumed if lowering within the OEM ability with the threaded shocks it should be ok though unless also doing a very aggressive tire fitment.
Old Jun 21, 2024 | 04:26 PM
CAINCA's Avatar
CAINCA
Good catch.
OP: I ran stock height with the track alignment and it was great. I don’t think most of us would be able to tell the difference on track anyway.
Old Jun 21, 2024 | 06:59 PM
Chuck2012GS
I left 3 threads on shock at the bottom. I do not find any rubbing, so far. The car feels much better, handling wise at this height. I found car a little sloppy, at stock height. Thx for input
Old Jun 21, 2024 | 07:02 PM
Chuck2012GS
I will test out, when at the track and work my way up to speed, to see if there are any issues. I would wonder why, they would give you the choice of lowering, the car, if it could cause damage. I’ve driven it pretty hard, on the street, with no sign of rubbing or bottoming
Old Jun 22, 2024 | 09:39 AM
AHP's Avatar
AHP
Mag-ride with front lift so my front height wasn't adjustable. I ran the GM-spec track alignment with the rear essentially bottomed out, per recommendation of my chassis/alignment guy. 15+ track days and the car felt very sharp on the nose and rotated nicely. The only thing I would change would be more rear camber judging my the outer shoulders.
Old Jun 22, 2024 | 12:16 PM
CAINCA's Avatar
CAINCA
So you lowered the rear but left the front alone? That’s an option I hadn’t considered. I’ll keep that in mind if I update the alignment.
Old Jun 22, 2024 | 12:47 PM
AHP's Avatar
AHP
Correct. No front height adjustment with the front lift option.
Old Jun 22, 2024 | 05:02 PM
mikegr's Avatar
mikegr
Did you drive car on track both before and after this suspension adjustment? Really curious how it felt? My car definitely had some understeer in stock configuration. Lowering the rear would potentially make this more noticeable.
Old Jun 22, 2024 | 05:09 PM
Chuck2012GS
hi, no I just know a lower car is better. Lower CG. I have been beating on it in the streets and parking lots, no rubbing scraping. I think it will be fine. I did notice the car felt less wobbly and more planted to the ground. It also looks muck better without those giant gaps between tires and wheel arches.
Old Jun 23, 2024 | 10:21 AM
AHP's Avatar
AHP
No, I had my guy do the alignment before I tracked the car. He has a LOT of setup experience but mine was the first C8 he had done. I trust him implicitly -- I gave him the car, the GM specs and told him to do whatever he recommended. I didn't even realize the rear was lowered until I had the wheels off to do brake pads and noticed the collars were near bottomed out.
RE: understeer -- what took me a few days on track to start to figure out is you can't drive this car like a front-engine (like my C7Z). It's a much different approach to take advantage of the weight being behind you. Understeer went away and lap times dropped once I started to get my head around that.
To Lowering C8 before tracking it
Old Jun 23, 2024 | 10:49 AM
mikegr's Avatar
mikegr
I was coming from a much different platform as well but one that had a ton of rotation and a large tendency to oversteer with a much higher power to weight ration. The C8 is way easier to drive. I was driving an AC cobra that had a weight distribution of 46% front/ 56% rear and 600whp on a 2500# platform. That car was a handful.
Old Jun 23, 2024 | 10:54 AM
Chuck2012GS
I have been driving and racing front engine car, my entire life, I know it’s going to take time for me to get used to a mid engine, but I’m sure I will master it, after a few track day.
thx for your input
Old Jun 23, 2024 | 11:25 AM
Chuck2012GS
I can imagine, but sounds like blast to drive!!
