Sponsored by: CARiD
Powerstop brake pads??
Old Jul 11, 2024 | 11:08 AM
08velocity's Avatar
08velocity
St. Jude Donor '13
Default Powerstop brake pads??
Ordered the Powerstop brake pads, just curious if you installed them yourselves, did you pull them from the top of the caliper or remove caliper and remove/replace from the bottom ? And which way is easier and the takes less time ? I've seen videos of both just trying to have an idea which will be easiest .
Old Jul 11, 2024 | 01:46 PM
Kracka's Avatar
Kracka
In reference to Z51s:
Front: Remove the caliper and replace them from the inside; its only 2 bolts. I've done multiple C8s this way. No special tools needed.
Rear: Remove the two pins and slide the pads out; no need to remove the caliper unless you're changing rotors too.
Old Jul 11, 2024 | 02:38 PM
08velocity's Avatar
08velocity
St. Jude Donor '13
Thanks Kracka!! That's sort of what I figured.
Old Jul 12, 2024 | 08:25 AM
Z51CYA's Avatar
Z51CYA
Fronts remove caliper.MAKE SURE YOU DISCONNECT BATTERY FIRST. Rears change from top. Way less dust. Good brakes. Make sure to bed them correctly.
Old Jul 12, 2024 | 10:48 AM
Ricketts's Avatar
Ricketts
Precisely! And like Z51CYA mentioned, disconnect the battery. You’ll be SOOOOOOOO much happier with the almost non existent dust levels of the power stops.
Old Jul 12, 2024 | 12:43 PM
08velocity's Avatar
08velocity
St. Jude Donor '13
One more question, is there a specific lube/ grease to stop the annoying squeal ?
Old Jul 12, 2024 | 01:08 PM
BLUE1972's Avatar
BLUE1972
Old Jul 12, 2024 | 02:08 PM
Kracka's Avatar
Kracka
PowerStop includes a packet of brake grease in each box. If you need more, this stuff is similar (but orange instead of gray):
https://www.oreillyauto.com/detail/c...ubricant&pos=0
To Powerstop brake pads??
