St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16 -'17
Redesigned C8 Corvette Painted Open Design Waterfall Extension
We have redesigned these and released a new version. We have both of these available now.
The original design is the full panel, the new design is the open face.
These C8 Corvette waterfalls are handmade right here in Ohio by our skilled craftsman and craftswomen, utilizing the highest quality ABS materials available. Each waterfall extension is custom painted to order, to make the exterior body color of your Corvette, adding exciting style to your car. Our open design allows you to charge your phone and use this waterfall extension at the same time.
Will the full faced closed cover fit over the waterfall that has the charging feature? I never use the charger and like the look of the closed panel better. Also is it taped down or permanently attached or can it be easily removed if one wishes to?
Hi Sir .. Yes, it’s a quick and easy install. It’s not hard and requires no tape. It covers the entire area. Please use coupon code LABOR24
