Sponsored by: CARiD
Launch Control with a throttle control device?
Old Sep 19, 2024 | 02:41 AM
avigar's Avatar
avigar
Default Launch Control with a throttle control device?
Has anyone done it? Just wondering if achieved time is lower vs. with the OEM setting? Since the OEM throttle lag can be significantly reduced, I'd assume Launch Control time would be much lower. Thanks.
Old Sep 19, 2024 | 03:50 PM
MarkMeHopeful's Avatar
MarkMeHopeful
2022 C8 of the Year Finalist - Modified
When you use launch control the throttle is already floored and the engine is at 3000 rpm before the launch, so I don't think there would be any lag. I doubt a throttle controller would make any difference. Going from idle to wide-open-throttle might be a slightly different case.
Old Sep 20, 2024 | 09:26 PM
itsonlyairandfuel's Avatar
itsonlyairandfuel
Your pedal may be on the floor, but your throttle body blade probably not at 100%. Just log your car to find out.
Old Sep 20, 2024 | 10:08 PM
MarkMeHopeful
I won't be able to tell anything because I already have a Soler Throttle Control on my C8. But we're talking throttle lag, not whether the blades are open 100%. I just don't think lag comes into play when your engine is already running at 3000 rpm for a few seconds before you release the brake. The limited slip differential probably has more of an effect in that situation.
Old Sep 20, 2024 | 11:43 PM
winders's Avatar
winders
It's obvious that the throttle body blade (or blades on the Z06) is not at 100% open when using launch control with the pedal floored otherwise the revs would be considerably higher.
It's very likely that a product that plugs into the pedal and alters the throttle curve would have zero affect on 0 to 60 MPH times. Why? Because the pedal is fully depressed and the drive by wire system would be told the pedal position is at 100% with or without the pedal controller in place. So there is no curve to manipulate.
Old Sep 28, 2024 | 02:49 PM
Red Mist Rulz's Avatar
Red Mist Rulz
With the pedal floored, the ECU is seeing the same voltage from the pedal whether you have a throttle control module installed or not. The Soler and similar units only change the progression of voltage, not the maximum. So no, adding something like the Soler won't increase performance with the pedal floored. To itonlyairandfuel's point, the ECU decides how far to open the throttle for any given voltage, based on multiple other conditions*, so without some sort of logging tool there's no way to know how far the throttle actually opens when using launch control.
*Traction control and Stabilitrak, for example, intervene when necessary and reduce throttle even when the pedal is floored.
To Launch Control with a throttle control device?
