Sponsored by: CARiD
Tire replacement question
Old Oct 6, 2024 | 09:36 AM
Baron92's Avatar
Baron92
Default Tire replacement question
Recently had a run in with a piece of cement sticking up on the road at 60 mph and destroyed my aftermarket rims and tires on the passenger side of my car. I ran the stock silver wheels for a week and the car drove straight and the alignment seemed fine. After installing the new rims and tires on passenger side the car pulls hard to the passenger side when steering wheel is straight. I had roughly 3k miles on the Michelin PS4S that are on the driver side could there be that much wear already that its causing it to pull that hard?
Old Oct 6, 2024 | 03:06 PM
Kracka's Avatar
Kracka
Sounds like an alignment issue and not so much tire wear variance with only 3k miles. With a hit hard enough to destroy wheels & tires, your alignment is definitely tweaked.
Old Oct 6, 2024 | 08:28 PM
RKCRLR's Avatar
RKCRLR
I agree with the above but if you want to verify swap the tires side to side. If it still pulls the same direction it's the suspension. If it pulls the other direction it's the tires. Or just take it in for an alignment and hopefully something isn't damaged.
To Tire replacement question
