Sponsored by: CARiD
Need help fast!!! Dash went blank, only the dash.
Old Oct 18, 2024 | 08:28 PM
hippiefreak67's Avatar
hippiefreak67
Default Problem solved
EDIT;
I did what Mark9 suggested and have full functionality back on the dash display.
Thanks all for the fast lifelines!
Need help.
I am supposed to be on the track tomorrow, I am about 2 hours from home. Staying in a hotel.
I went to grab a bite and came back out to go to hotel.
Started car, all is well, backed out, went to Drive, made way to road. Pulled out and went to look at speed on dash. DASH IS BLANK.
Infotainment is on working fine.
HUD is up and scrolls thru different modes.
Rotated Dash lights ****. Infotainment levels change but NOTHING on dash.
* When I first started the car, I went to PDR and turned recording off.
I do not know when the dash went blank. Parking lot was busy and I was watching other cars.
Old Oct 18, 2024 | 08:51 PM
Mark9's Avatar
Mark9
With the car off, leave the door open for a minimum of 90 seconds. Not less. Close the door and start the car.. See if that clears things up. If not, disconnect the negative side of the battery for a min or so and reconnect. Hopefully one of those two things will reset things.
Old Oct 18, 2024 | 09:10 PM
RKCRLR's Avatar
RKCRLR
I'd add that if you are using Android Auto/CarPlay sometimes the dash will go black when the car isn't happy about the connection for some reason. If you're using AA/CarPlay disconnect it and restart the car.
Old Oct 18, 2024 | 09:13 PM
hippiefreak67
Originally Posted by mark9
with the car off, leave the door open for a minimum of 90 seconds. Not less. Close the door and start the car.. See if that clears things up. If not, disconnect the negative side of the battery for a min or so and reconnect. Hopefully one of those two things will reset things.
it worked!!
Thank you!!!
Beers on me!
Old Oct 18, 2024 | 09:15 PM
hippiefreak67
I did what Mark9 suggested and WALA BADDA-BING!
I have my display back.
Will keep in mind your suggestion in case it happens again and his method doesn’t do the trick.
Thanks for the fast life line.
(I have an iPhone).
Old Oct 18, 2024 | 09:27 PM
Mark9's Avatar
Mark9
(I have an iPhone).
Great to hear. Shiny side up tomorrow.....
Old Oct 19, 2024 | 09:30 AM
Wadejesu's Avatar
Wadejesu
What worked, open door or disconnect battery?
To Need help fast!!! Dash went blank, only the dash.
