Sponsored by: CARiD
Corvette C8 2023
Old Oct 22, 2024 | 09:49 AM
KnorstBrasil's Avatar
KnorstBrasil
3rd Gear
Default Corvette C8 2023 - transmission problem
Greetings, my name is Angelo, I am from Brazil, and I had a problem with my Corvette.
With only 2,830 kilometers driven, the vehicle experienced a transmission problem. After evaluation, it was identified that the transmission needed to be replaced. The issue, which occurred on April 8, 2024, was caused by a displacement in the clutch drum, resulting in a puncture in the oil pressure tubing. This caused a significant reduction in transmission pressure, leading to premature wear of several internal parts and ultimately causing them to break.
Anyone else has experienced this problem and if it is related to the TSB #N232427051?
