Picked car, 2024 Stingray, up from install and CEL was on. They cleared it, drove it. Looked good. Came home. Shut her down for the night. Start up today. CEL back on again. How many times are people having to clear and relearn before it goes away permanently or does it ever? Went with Borla because they advertise that this wouldn't happen.
my luck. connected creador. was able to get it to see obdII port once and did the relearn. jumped on a call for work. went back out still have CEL and now creador wont connect as it doesnt see the obdII. ugh
I have read that it took some folks several relearn sessions to get it to stay. Personally, I rather just leave it there and let them recheck it the next day to make sure it is good. If it comes back, have them keep it again. At least saves me the back and forth.
Drive the car for about an hour and then do the relearn. What codes are you getting?
__________________ http://www.corvetteexhaustsystems.com sales@corvetteexhaustsystems.com
201-575-0861 (cell to call or text)
Your Ultimate Resource For Headers, Exhaust Systems & more for Corvette! I carry Corsa, Kooks, ARH, Borla, Billy Boat, Akrapovic, Capristo & Much More
Perhaps you are doing the same thing that I did. I did not remember that there are two relearn processes if you are not using the same "OB..." that GM uses. Which I finally remembered.
Problem is isolated to passenger side. Moved actuators to see if it the problem would move and still the same. Working with Borla to get a replacement valve sent out to the shop.
