Sponsored by: CARiD
belly pan bolts
Old Apr 27, 2026 | 02:21 PM
Jungtfl's Avatar
Jungtfl
Just get rid of the Torx and use these. Like I said in one of my earlier posts, the only reason Torx are used at the factory is for ease of using tooling for expedience. Your mechanic will thank you. Make sure you get non serrated, otherwise you will chew into the soft aluminum. John
Amazon.com: U-Turn Fasteners Flange Bolt - M8-1.25 x 25 mm Flange Bolts Flanged Hex Screws, DIN 6921, Non Serrated Strong & Reliable Zinc Made Frame Bolts Ensures Durability | (Pack of 10) : Industrial & Scientific Amazon.com: U-Turn Fasteners Flange Bolt - M8-1.25 x 25 mm Flange Bolts Flanged Hex Screws, DIN 6921, Non Serrated Strong & Reliable Zinc Made Frame Bolts Ensures Durability | (Pack of 10) : Industrial & Scientific
Old Apr 27, 2026 | 02:28 PM
Daedalus51's Avatar
Daedalus51
Originally Posted by C8ZZZ
My EP14 and E14 socket would not fit.
Wouldn't fit, as in wouldn't even seat over the bolt head? Maybe try a different brand of tool? First time I've read that on this board.
Old Apr 27, 2026 | 02:52 PM
C8ZZZ's Avatar
C8ZZZ
I have EP Torx and E Torx sets from different manufacturers. My EP14 and E14 would not fit over bolt head. Both 16 versions would fit over the bolt head.
Old Apr 27, 2026 | 03:59 PM
C8ZZZ's Avatar
C8ZZZ
I just rechecked my EP torx set, the lobes are not correct to match the EP profile. The product did not match the picture of the profile. My bolt head lobe to lobe was 12.7mm as expected for an EP14 bolt.
