Sponsored by: CARiD
Overheating POP noise
Old Mar 9, 2025 | 01:33 PM
CaperOne's Avatar
CaperOne
7th Gear
Default Overheating POP noise
My 2024 Z06 was being driven very slow in a parade. After about 25 minutes , without any alarms, I stopped and shut the car off and a popping noise came from it. Can anyone help explain this? Did I hurt the engine?
Old Mar 9, 2025 | 02:25 PM
Andybump's Avatar
Andybump
Why is "overheating" in your thread title? Your post does not say you had an overheat warning. What did the temperature gauge say? Did you seen any signs of overheating like steam or feel heat? Or is the pop sound the only symptom? Is it running now? More detail needed on symptoms (if there were any). Is the coolant level normal?
Old Mar 9, 2025 | 02:59 PM
CaperOne's Avatar
CaperOne
7th Gear
I guess I shouldn't have presumed it overheated. Now it was my wife driving and she relayed me the information. She corrected me on the sound , it was a HISSING sound. Driving slow, then stopping and hearing a hiss made me think safety valve. temp 105C. No steam or heat. hiss only symptom and I have it in storage since, i had been out of province.. I did start it. All fluid Levels normal. 1100.km on car. Soory for the poor description.
Old Mar 9, 2025 | 03:07 PM
drwoof's Avatar
drwoof
Cooling fans coming on, perhaps? Are either of you familiar with the sound they make?
Old Mar 9, 2025 | 03:25 PM
CaperOne's Avatar
CaperOne
7th Gear
not familiar with the fan sounds.
Old Mar 9, 2025 | 04:32 PM
drwoof's Avatar
drwoof
They're not a 'hissing' sound, per se, but do whir; a rush of air driven by a small electric fan. Am wondering if your wife heard that as a 'hiss'. The 'popping' sound is odd, though.
Old Mar 9, 2025 | 04:53 PM
CaperOne's Avatar
CaperOne
7th Gear
Your correct , she did say that it could of been a fan. Thank You Very Much.
Old Mar 9, 2025 | 05:09 PM
Andybump's Avatar
Andybump
Yes, then very likely a fan! Two in the back, and two in the front. And, very often (well sometimes), they will come on right after the car is shut off. Happens sometime when I am driving mine, then pull into the garage and shut off the engine.
combatninja's Avatar
combatninja
Never let your wife drive the car again, clearly.
Old Mar 10, 2025 | 05:02 PM
CaperOne's Avatar
CaperOne
7th Gear
Ha ha , I got you, That car is so fun ,,, to drive fast,
To Overheating POP noise
