I got two low oil pressure warning’s about 1-2 second in duration before it disappeared immediately both times. I am at 20% oil left currently. I started the engine and when it was warm, I checked the oil level and there was nothing on the dipstick. Is that normal for oil levels at 20%? I have an appt with my local Chevy dealer tomorrow but will put a quart of oil in the engine before I take it tomorrow. Unless the Forum suggests I should be fine without adding a quart. Thanks for your responses!
Let’s hope no engine damage. Nothing on the dipstick is not normal. Do not start or drive until you put oil in it.
20% is not your engine oil level, it’s you engine life which is totally different. Don’t start your car until it has the proper level. Also, why are you low on oil? Did it just get changed, is there a leak?
I go roughly 6,000 miles religiously before changing the oil. I’m at 5,600 miles and roughly 5 months since my last oil change. I have 72,000 miles on my 2021 vette so I’ve been doing this for awhile. No oil on garage floor so I don’t have a leak.
Well it’s going somewhere…. I’d top off and check it every fill up to track consumption. Something seems amiss
Any idea how much oil is needed before I will see it on the dipstick?
not sure. Depends on how much it was down. Hopefully not more than a quart or two max. I’d fill cold until it just shows on dipstick then check when oil temp is at 175
From: Early 2020 Z51 Coupe, Original Owner, Ahwatukee Foothills, AZ
You may have been mistakenly underfilled on your last oil change. With 72K on your MY 2021 thinking your would know if your burning oil.
In 5 months have you checked your oil since your last change? If yes you have, dropping 1 1/2 quarts in the last 1000 miles doesn't add up.
I have a rough guess. You said you saw the low oil pressure light come on. The primary means of lubrication is the oil that is pumped out of the tank into the engine lines. The oil pan (or sump) is described as a dry sump and holds very little oil. When the engine is off, oil will slowly seem into the pan, but when running the oil that lubricates the engine runs down to the pan where it is quickly scavenged and returned to the oil tank. The point is, the majority of the oil in the tank when the engine is running. And the capacity is something like 7-8 quarts - I think most in the tank. If you saw a low oil pressure light, that means that the tank was drained so much that it sucked air - and the oil is pumped from the bottom. So my guess is a lot of oil is missing. Wow. I hope I am wrong.
I wish I was a grease monkey but I’m the opposite. I am adding a quart of oil shortly when the engine is cold, then idling until the temp is 175 and checking the dipstick. If nothing is on the stick, I’ll put another quart in tomorrow morning and check again before I drive it to my service appt. That’s all I can do right now I think.
I would suggest not going more than 1500 miles before checking the oil level. It’s a good habit. This is after the 1st 1500 miles, before that it is suggested that you check the oil every fill up.
So, it only takes 20 seconds to get all the oil back into the the tank. I know this because the oil change procedure in your owners manual says this, as part of the oil change procedure: "1. Run the engine at idle for about 20 seconds to return all of the oil back into the dry sump oil tank." And, although you are supposed to check the exact level when the oil is hot, the total volume of oil wont change that much. I would run it 20 seconds, then bring the oil in the tank at least to the bottom of the hatched region on the dipstick. Then warm it up and adjust the level.
If its so low that you got a low pressure warning, I would not want to be running it much until it was filled properly. I suppose its safe since you have oil pressure most of the time. But you may have other issues - like - what happened to all that oil.
If you only saw the light for a few seconds like 5-10s you should be ok. You should fill it to the correct level before driving it to the shop to have the oil changed. After the oil change you should check the level to make sure the shop puts enough oil in the car, some shops may be a little stingy with the oil or didn't measure it correctly last time you had an oil change (at least halfway up the good area, I always put in 8 qtrs which brings it to the top line). Then you need to monitor you oil level after every fill up to see if that was just a fluke or you may have some issue causing excessive oil usage. With 72K miles it's possible that something is causing excessive oil usage. Oil lubricates and helps cool the motor being jus 1 qtr low may not hurt the luberacation but it does reduce the cooling capability.
I'd be checking the oil level with the dipstick more frequently.
Well @cdurkin1259
Might be good of you to update all who responded to your dilemma.
Here is the end result of my plight. I ended up putting 4 quarts of oil in the engine to ensure I would get to the local Chevy dealer without issue. The dipstick still did not show oil but I knew I had enough to get to the service appointment. When the car was serviced and I got it back, the mechanic showed me how to check the oil. When he did, the oil was at the proper place on the dipstick. What he did tell me which was different from what I was doing was to get the engine temp up to 175, then shut the car off for 5 minutes, then check the oil. I was checking the oil while the car was running on idle. My guess as to why I had an oil pressure warning flash for a few seconds was I was low on oil but not in danger of seizing the engine immediately. It should be noted I never got a “low oil” warning which I assume I should have gotten. Additionally, I can only guess that the previous oil change did not get the full 7.5 quarts of oil needed which is why I was low at 6,000 miles between changes. I just checked the oil yesterday and it registers full so I hopefully don’t have a leak. I will be checking the oil occasionally from now on. Thanks everyone for your advice and be well!
