Sponsored by: CARiD
MAC or PC for PDR / Catalyst
Old Apr 2, 2025 | 06:31 PM
Midwest C6's Avatar
Midwest C6
Default MAC or PC for PDR / Catalyst
For those reviewing lapping sessions from your PDR and Catalyst in-between sessions, are you using a PC or MAC.
Time to get a new computer I can travel with. Always had PC, but considering a MAC?
Dave
Old Apr 2, 2025 | 09:00 PM
Mark9's Avatar
Mark9
PC for me as I've never owned a MAC. I think I recall an issue with using MAC with the PDR toolbox but could be mistaken.
Old Apr 3, 2025 | 10:17 AM
Midwest C6's Avatar
Midwest C6
I should have been more clear. I can only seem to find the Cosworth Tool Box software for Windows. Is there a version for the MAC?
Old Apr 3, 2025 | 10:45 AM
Mark9's Avatar
Mark9
Based on my research, no. You'd need to have an emulator program to work with Cosworth. See below from Grok:
The Cosworth GM Toolbox is designed specifically for Windows operating systems (typically Windows 7, 8, and 10, as noted by Cosworth), and there is no native version available for macOS. Cosworth has not released an official Mac-compatible version of the software, and their support documentation does not indicate plans to do so.
However, you can still use the Cosworth GM Toolbox on a Mac by employing one of these workarounds:
  1. Virtual Machine (VM): Install a virtual machine software like Parallels Desktop, VMware Fusion, or VirtualBox on your Mac. Then, set up a Windows environment within the VM and install the Cosworth GM Toolbox there. This allows you to run Windows applications seamlessly alongside macOS.
  2. Boot Camp: Use Apple’s Boot Camp utility (pre-installed on Intel-based Macs) to install Windows on a separate partition of your hard drive. You’ll need a valid Windows license, and this method requires restarting your Mac to switch between macOS and Windows. Once Windows is running, you can install and use the Toolbox as intended. Note that Boot Camp is not available on newer Apple Silicon Macs (M1, M2, etc.).
  3. Windows Emulator: Software like Wine can sometimes run Windows applications on macOS without a full Windows installation, but compatibility with the Cosworth GM Toolbox is not guaranteed and may require technical tweaking.
Old Apr 3, 2025 | 10:50 AM
Midwest C6's Avatar
Midwest C6
Thanks, I found similar. I will take it as a sign and go PC!
To MAC or PC for PDR / Catalyst
