Sponsored by: CARiD
Expectable Variance Between Long Term Fuel Trims Banks
Old Apr 15, 2025 | 09:06 AM
jjk2509's Avatar
jjk2509
Default Expectable Variance Between Long Term Fuel Trims Banks
I recently replaced my airbox, throttle body and HFC. My scanner shows bank number 1 running at about 10% while bank two is at 4% (this is at idle).
The car is at 13% and 7% while driving. The numbers have decreased as I drive the car over time (100 miles). I have been told the car will keep learning and adjust.
Is it ok to have a 6 to 7% variance between the 2 banks or does it indicate I may have a small leak from my install?
Bank #1 (is that the driver's side)?
Old Apr 15, 2025 | 11:00 AM
Bobbo76's Avatar
Bobbo76
Veteran: Canadian Forces
Did you preplace the gaskets when you did the cats? If not MAYBE there is a leak at one of the flanges. Watch for carbon marks. Maybe an issue with the O2 sensors? What are you seeing at WOT?
If able perhaps have someone with HP Tuners plug in and have a look. That will provide you with much more information.
This is an interesting one. Good luck and please report back with your findings.
This MIGHT help
Old Apr 15, 2025 | 01:57 PM
jjk2509's Avatar
jjk2509
This MIGHT help
https://youtu.be/Rhg5NSh8Dq8
Thanks for the video. I have looked for carbon and did not see any signs of a leak. I need to do a smoke test before I start removing parts. It would be good to know if it is ok for bank 1 to be 13 and bank 2 to be 7. If so I would keep driving the car. If I was 2 off, I wouldn’t worry.
Old Apr 15, 2025 | 10:09 PM
Mitchell_B's Avatar
Mitchell_B
There are many things that ultimately affect your fuel trims. The missing piece of the puzzle is - what your trims were before your component changes. Barring this, my question is: does your airbox change the way air flows across the MAF? If it does, this alters the engine's load calculation and this, in turn, will affect other things. It would be a good idea to double check for an exhaust leak. By itself, your trims are a little discerning, but within the realm of what is acceptable.
Old Apr 15, 2025 | 11:11 PM
jjk2509's Avatar
jjk2509
I am doing a smoke test tomorrow am before I remove any parts. Everything I read says numbers over 10 at each bank could be a problem and the total of the short and long term numbers should be 10 or less.
I am hoping, after a few more miles, the numbers will come down. I am really concerned bank 1 is too high.
Old Apr 15, 2025 | 11:39 PM
Mitchell_B's Avatar
Mitchell_B
If you are using an ethanol blend - even 10%, your trims will be adding fuel to the tune of around 5% compared to straight gasoline.
Old Apr 15, 2025 | 11:47 PM
jjk2509's Avatar
jjk2509
Do you see a variation of 8% between bank 1 and bank 2 being a problem?
Old Apr 16, 2025 | 12:24 AM
Mitchell_B's Avatar
Mitchell_B
I would like to see it half that amount.
To Expectable Variance Between Long Term Fuel Trims Banks
