Sponsored by: CARiD
Clutch HELP
Old Apr 26, 2025 | 05:41 PM
LucilleTBV's Avatar
LucilleTBV
6th Gear
Default Clutch HELP
I am running a built 2004 c5 with stock trans and supposedly “tick performance clutch, master and slave cylinder” looking at the master I’m believing that to be false. Since the car was bought it has always struggled on take off and taking off on hills were not an option. It also would slightly grind and “grab” when I’m in a gear driving and would push the clutch to rev at someone. Last time it was drove a month ago I was getting on it and it worked fine until it didn’t. WHEN STOPPED clutch in put into first gear when I try to take off it scratches / grinds pretty loud until I am rolling and peddle is fully decompressed. I’m seeing it is between master / slave / throw out bearing but I’m told different every time.
Old Apr 26, 2025 | 10:20 PM
DrivesWithTwoFeet's Avatar
DrivesWithTwoFeet
This is the C8 section. Try posting in C5 Tech/Performance for help.
Old Apr 28, 2025 | 10:37 AM
LucilleTBV's Avatar
LucilleTBV
6th Gear
I didnt even see it said c8😭
To Clutch HELP
