Sponsored by: CARiD
2023 iat temp sensor location
Old May 4, 2025 | 07:35 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
Default 2023 iat temp sensor location
Can anyone post me a photo of where exactly is the IAT sensor located on a C8 Base Model ? I believe it is under the airbox on the Pass side but not sure
ALSO I've read where this sensor can pull as much as 5-6 degrees of timing via "heat soaking "
My car here in Calif where it gets to be 105-110* lays down in the afternoon big time
Is there any easy fix ?
Insulation of the air box
Insulation of the IAT itself
Re location of the IAT
Unplugging it for drag racing only
IAT tricker with a OHM resistor
Anyone any thoughts ? THKS
Old May 6, 2025 | 02:05 PM
tblu92's Avatar
tblu92
73 views and "0" replies ?????
Does anyone have any quick ideas on how to LOWER IAT temps to bump up the timing ?
Remove air filter carper trunk liner ?
Insulation ?
Please anyone Does anyone make a part to cool off the air box and the IAT sensor ?
In older C5's we would install a IAT TRICKER OHM resistor that would lower the IAT temps to whatever you thought was correct Sometimes only 5-6* or sometimes as much as 10-12* as the older C5's would spike always to about 130-140* just with normal driving
HELP !!!!
