Sponsored by: CARiD
Chevron Techron
Old May 6, 2025 | 09:23 AM
Corvette03051's Avatar
Corvette03051
Default Chevron Techron
Sorry if this has been discussed and I may have missed it. Has anyone used Chevron Techron in their C8 Stingray?
is it safe and did you notice any differences? Thanks for the help!
Old May 6, 2025 | 09:56 AM
Mark9's Avatar
Mark9
Safe. Unless there's an issue you won't notice any difference. Best to use Top Tier gasoline regardless.
Old May 6, 2025 | 12:06 PM
X25's Avatar
X25
Sr.Random input generator
Yep, Chevron and 76 are the best fuels in my area (Pacific Northwest).
Old May 6, 2025 | 01:05 PM
Bobbo76's Avatar
Bobbo76
Veteran: Canadian Forces
Chevron and Shell are my go-tos in my corvette, X5 and SXS. Used it without issue in my SC 383 C5 as well. Never had an issue.
Old May 6, 2025 | 03:00 PM
Corvette03051
Default Gas
I’m a mobile and shell guy
Old May 6, 2025 | 03:11 PM
Andybump's Avatar
Andybump
Techron is one of the "approved" additives for Top Tier fuel. If using TopTier, techron is not needed. If not using top tier, the owner's manual recommends the use of ACDelco Fuel System Traatement - but only every 9000 miles or every oil change - so infrequently. Because its suggest in lieu of TopTier, I believe that its either the same as, or similar to the Techron fuel additive. Meaning its safe when used in the quantities recommended. I do not use it and see no reason, generally to use it if using TopTier fuel.
"If your country does not have TOP TIER Detergent
Gasoline, add ACDelco Fuel System Treatment
Plus – Gasoline to the vehicle’s gasoline
fuel tank at every oil change or 15 000 km
(9,000 mi), whichever occurs first."
Old May 6, 2025 | 04:46 PM
Orion2011's Avatar
Orion2011
Techron is one of the few additives that actually cleans things.
To Chevron Techron
