Sponsored by: CARiD
PDR Question
Old May 17, 2025 | 05:14 PM
hippiefreak67's Avatar
hippiefreak67
Default PDR Question
Thanks everyone for the input.
Got it figured out via everyone's tips.
Much appreciated!
Last edited by hippiefreak67; May 20, 2025 at 07:50 PM. Reason: Issue resolved - please delete
Old May 18, 2025 | 06:41 AM
Black E's Avatar
Black E
Yes you’ll see the traction control symbol blinking on screen when it kicks on
Old May 18, 2025 | 10:28 AM
hippiefreak67
On the PDR recording, not on the dash itself?
Sorry if I sound stupid, but I am pretty sure it came on a few times and I cannot find it in the recordings.
I want to go back and see where I was on throttle or brake.
Great learning tool.
Old May 18, 2025 | 10:45 AM
Black E's Avatar
Black E
both
If you want ALL the data you should learn and use Cosworth PI
Old May 18, 2025 | 11:00 AM
hippiefreak67
both
Will look that up.
Old May 20, 2025 | 01:05 PM
mittens's Avatar
mittens
The PDR will not effect the Dash lights. they will work as usual. So if you had traction kick on it should have flickered.
That same symbol will light up on the PDR recording in track mode. But most tracks are already saved and you can just save it to your card. then select the track. worked awesome for Barber. also you can save a track/ road then rename it on the card so you can select it later. and save another.
Old May 20, 2025 | 03:31 PM
rlhammon's Avatar
rlhammon
Good day fellow enthusiasts.
I have a 2022 C8.
I am doing a track event with NASA Mid-America.
I am in track mode, and I configured the PDR to learn the track.
Hedge Hollow Raceway in Adrian, Missouri.
Does the PDR recording annotate if traction control is coming on and off as I drive?
Where on the display would it indicate this if it does?
Thanks in advance.
You'll want to pull the card from the car and load it up in either the gm or Cosworth versions of the software. The gm is far more "simple", so start there and see if it shows you want you want.
gm Version
https://download.cosworth.com/downlo...r/GM/Index.htm
Cosworth Corvette version
https://www.cosworth.com/motorsport/...-for-corvette/
Both are free, the Cosworth is much more powerful but more complex to use IMO.
To PDR Question
