Sponsored by: CARiD
CC brake caliper torque Spec
Old May 22, 2025 | 12:49 PM
Gunny27's Avatar
Gunny27
Veteran: Marine Corps
Default CC brake caliper torque Spec
I'm about to change my Carbon Ceramic Brake calipers for a set powder coated Seabring Orange to match the car. Could someone tell me the Torque speck for the mounting bolts and the banjo bolt? Thanks
Old May 22, 2025 | 02:25 PM
JayO's Avatar
JayO
210 Nm (155 lb ft)
Old May 23, 2025 | 11:45 AM
Gunny27's Avatar
Gunny27
Originally Posted by JayO
210 Nm (155 lb ft)
thank you
Old May 23, 2025 | 06:13 PM
noticket's Avatar
noticket
The fronts are 155lb ft.
The rears are 74lb ft and then 15-30 degrees for the caliper bolts.
The banjo bolts are 30lb ft.
Brake hose bracket is 80lb in. Wrist tight.
Old May 24, 2025 | 07:58 AM
Gunny27's Avatar
Gunny27
thanks
To CC brake caliper torque Spec
