Sponsored by: CARiD
Installed Soler TB, Now I Have Codes
Old Jun 2, 2025 | 12:10 PM
08redrocket's Avatar
08redrocket
Default Installed Soler TB, Now I Have Codes
I installed a Soler TB in my 23 2LT Z51. I now get two codes, the engine light is on and "Service Auto Start System". How do I clear these codes?
Old Jun 2, 2025 | 12:25 PM
SinisterC6's Avatar
SinisterC6
Speedy
2024 C8 of the Year Finalist - Modified
You can disconnect the battery for a bit and should clear.
Autozone will scan and clear for free
Id just buy a code reader from walmart or harbor freight, it helps on these newer cars. The more advanced units can read codes from the body control module
Old Jun 2, 2025 | 12:49 PM
08redrocket
Thanks SinisterC6
Old Jun 2, 2025 | 01:07 PM
SinisterC6's Avatar
SinisterC6
Speedy
Thanks SinisterC6
Easiest is unplug battery, double check all you connections and reconnect batteryu in 30 min. Dont forget the pesky locking pin on the electrical connectors
Heres some options
I have the centec and zuric cr11, zuric can read and clear stuff about suspension other non engine systems.
On my C8 I went with a bluetooth adapted and run the app Torque on my phone, kinda cool because you can see everything the computer sees in real time. Can also set up to auto clear codes like for catless exhaust
bluetooth adapter bluetooth adapter
To Installed Soler TB, Now I Have Codes
