Sponsored by: CARiD
DCT top Brass fill plug Torque value?
Old Jun 19, 2025 | 04:45 PM
Strake's Avatar
Strake
2020 C8 of the Year Finalist - Unmodified
Phil, THANKS SO MUCH for going the extra mile and measuring your original plug. From what I see, it looks like it should work including using the O ring in addition to the crush washer.
I’ll find out in a few days and report back!
Old Jun 19, 2025 | 05:26 PM
Phil1098's Avatar
Phil1098
You're welcome, glad to try and help out! Please do report back after your setup is in place. Remember to give the OEM plug a sharp snapping motion to loosen it and not a steady pull.
Old Jun 20, 2025 | 09:55 PM
Mike Jesse's Avatar
Mike Jesse
Earl's Performance makes a crush washer with an o ring molded into the I.D.
It's called a Stat-O-Seal.
Used them in the past and they work perfectly.
You can find them on the Holley web page.
Old Jun 26, 2025 | 12:10 PM
Strake's Avatar
Strake
Originally Posted by rlhammon
This is the what I used as well.
The banjo bolt is a low grade M12 bolt. Recommended torque on a M12 class 4.6 bolt is 24 ft-lbs. In this case we aren't looking for clamping strength, only compression enough to cause the washers to seal.
For references:
Wildwood (M10 bolt on the banjo bolt for the caliper)
https://www.wilwood.com/PDF/DataSheets/ds573.pdf
States 120 in-lbs (10 ft-lbs) do not exceed 144 in-lbs (12 ft-lbs)
Hose and fittings site for banjo bolts:
I find it handy to keep this chart next to my thread gauge (if you don't have a thread gauge get one)
https://crafter.fastenal.com/static-..._Fasteners.pdf
Prevents me from having to look up torque values on everything all the time.
Rich,
A few weeks ago when I PM'd you regarding doing this mod, you said the Banjo fitting was a 6AN to 14mm x 1.5 which is what I ordered. I'm ready to do this mod tomorrow and I'm concerned that it's a 12mm x 1.5 Banjo bolt. You reference 12mm in your reply on torque value above.....
Do you recall is it's 12mm or 14mm Banjo bolt into the DCT ??? I've already got the 14mm size, but if I need to reorder it in 12mm so be it....
thanks,
Richard
Old Jun 26, 2025 | 01:29 PM
rlhammon's Avatar
rlhammon
Rich,
thanks,
Richard
Typo before... here's a picture of the top of the plug in question. It shows on the plug M14 x 1.5
