Sponsored by: CARiD
3lt Leather Dash Removal Instructions.
Old Jul 8, 2025 | 03:50 PM
Kenny94945's Avatar
Kenny94945
Default 3lt Leather Dash Removal Instructions.
Yep, my dash adhesive has separated along the edges.2023 HTC 3LT.
Additionally, it appears that these edges have dried out more than the other surface of the dash, and one edge seems to have shrunk.
The dash panel in question is the passenger side panel that extends across the dash and covers the airbag - leather w/ red stitch.
I understand this will be covered by 3/36 warranty.
My preference is a complete panel replacement.
Yet, does anyone have a printout of the factory service manual to remove this panel?
I'd like to see what is involved.
Thanks co-members
Old Jul 9, 2025 | 12:29 PM
gsvette's Avatar
gsvette
Hoon
See attached……a LOT of work. The typical dealer gorilla wallowing all over the interior with myriad chances to break tabs, strip screws, scratch stuff, grease stains, boot scuffs and squeaks and rattles later on = ughhh.
It’s boggling GM still hasn’t figured out how to bond leather.
File Type: pdf
Old Jul 10, 2025 | 07:21 AM
Kenny94945's Avatar
Kenny94945
Holey Moley... does not look like plug & play.
I only need to remove the Instrumnent panel upper trim panel replaced.
I see the airbag is attached to it.
No short cut?
Center front floor console, rear compartment close out panel, and instrument panel knee bolster all need to be removed?
Really need an experienced tech to do this, yes?
PS Thank your GSVette
Old Jul 10, 2025 | 02:10 PM
kromdom's Avatar
kromdom
Before you take your car in for warranty work, VERY highly suggest that you REALLY inspect your left & right door panels also.
Old Jul 10, 2025 | 08:16 PM
Zaro Tundov's Avatar
Zaro Tundov
Porsche has this same problem, it’s the nature of leather on a hot dashboard to shrink and lift.
Old Jul 14, 2025 | 04:00 PM
A471133's Avatar
A471133
There's a channel on youtube, Squirrel Cage garage if I recall right. Great videos, the guy took the interior of the C8 dash apart. I used his videos when I replaced some dash trim panels. Takes a while but if you are comfortable wrenching it yourself its pretty easy, just take your time with each panel.
Old Jul 14, 2025 | 08:38 PM
FinallyAVette's Avatar
FinallyAVette
8th Gear
i'm currently looking at a '21 3LT. The leather dash cover(black) has loosened from the dash (no issues that I can see on edges). When the AC is on in the car the leather smooths out and is not noticible. This car has the translucent roof panel and has spent time in FLA. Has anyone else experienced this? What is the fix?
Old Jul 15, 2025 | 12:33 AM
superramvette2's Avatar
superramvette2
Thanks co-members
Pay close attention to the passenger side large panel part in the PDF. The airbag has to be replaced each time this is removed. I have one at my house right now this is how I know. Not cheap.
Old Jul 20, 2025 | 05:25 PM
druz06's Avatar
druz06
+Squirrel Cage used it to remove interior panels when I dyed the stiches orange on my 2LT. If under warranty take it into dealer. I know it can be frustrating.
To 3lt Leather Dash Removal Instructions.
