Sponsored by: CARiD
Frunk Warning Light
Old Aug 5, 2025 | 02:43 PM
C8Z06's Avatar
C8Z06
Default Frunk Warning Light
Hello All:
a couple times I’ve had a warning come up indicating my frunk was open and I needed to pull over and close it.
of course, it was not open and the message cleared on its own after ten seconds. My questions are:
1) anyone know what root cause is with a fix?
2) am I at risk the car would reduce power or leave me stranded?
Old Aug 6, 2025 | 10:30 AM
Bobbo76's Avatar
Bobbo76
Veteran: Canadian Forces
Yeah that's a weird one. I was at the track a couple of weeks ago and left the frunk open for about :30mins. I closed it, started the car and had the same warning. I opened and shut it a few times with no luck.
The final solution was to disconnect the battery for a short time and reconnect. Fault cleared and haven't seen it since but I'm careful to not leave it open for too long.
Old Aug 7, 2025 | 09:30 AM
undecided1965's Avatar
undecided1965
Default I leave mine open overnight every day
I usually take my tennis stuff out of the frunk overnight and I leave it open so I don't have to shut it and reopen it the next day, less wear and tear. In addition, I figured, if it ever has battery issues, I'd have easy access to the battery.
Old Aug 7, 2025 | 09:47 AM
Phil1098's Avatar
Phil1098
Originally Posted by C8Z06
Hello All:
It won't leave you stranded, but it would limit your speed to 26 MPH. That would be an issue on an interstate.
Old Aug 14, 2025 | 11:17 AM
stargtsi's Avatar
stargtsi
Happened to me as well randomly while driving. Freaked me out as I was going about 60 and it cut my acceleration down. I mentioned it to my dealer and they asked for a video. Thankfully only happened once so far.
Old Aug 15, 2025 | 12:14 PM
Wing252's Avatar
Wing252
Hey, this is a known issue in the 24-25s with the soft close. A few people have had success in making sure their battery is good as it turned out to be an electrical gremlin.
I had this, and wound up getting the frunk latch assembly replaced under warranty.
To Frunk Warning Light
