Sponsored by: CARiD
HTC upkeep
Old Aug 20, 2025 | 08:29 AM
ladder13's Avatar
ladder13
Default HTC upkeep
What should us HTC owners do to the top mechanism as part of maintenance on our cars? TIA
Old Aug 20, 2025 | 10:13 AM
patton's Avatar
patton
St. Jude Donor '09
I looked at mine and saw the gears had some grease on them .......done . I might put some spray silicone on the weather stripping once a year and clean the mating surface if i remember
Old Sep 1, 2025 | 09:28 PM
smp629's Avatar
smp629
Default Htc
=ladder13;1609039537]What should us HTC owners do to the top mechanism as part of maintenance on
I can't answer you question, but as someone who is considering upgrading from a C5 to a C* What is an HTC
Old Sep 2, 2025 | 12:08 AM
CDNZR's Avatar
CDNZR
Hard Top Convertible
Old Sep 2, 2025 | 09:14 AM
Kenny94945's Avatar
Kenny94945
Good question.....HTC upkeep
Anyone find a GM "how to", with recommended oils/ grease?
Gears, cables, hinges, and weatherstrips.
With only 6K mileage, I have not noticed any area of the mechanism building up with dirt/ debris.
I have noticed the weatherstrips near the rear window are not as supple as when new...I assume a lot of heat in that area.
Old Sep 2, 2025 | 06:43 PM
Karch22's Avatar
Karch22
I would be interested as well. I just had my 7,500 mile service done, not sure if they even lubed anything for the hard top. Is this even on the list to do at that service?
Old Sep 5, 2025 | 08:44 AM
Kenny94945's Avatar
Kenny94945
Bump TTT
No one has found any guidance?
At the very least GM recommended gear grease.
Old Sep 5, 2025 | 08:58 AM
CDNZR's Avatar
CDNZR
I suppose just do your own research as to which product best to use for those area of contacts.
My main concern is finding a better solution for that wirerope that comes apart because of an inferior crimp on certain HTCs. In my observation.
Old Sep 6, 2025 | 03:13 PM
Red Mist Rulz's Avatar
Red Mist Rulz
There is no recommended service for it. I never saw any grease on the gears when mine was new in 2021. Any grease you put on them is going to attract dirt and dust and create a grinding compound. If you feel a need to lube them, I'd use a dry lube that won't attract dirt.
To HTC upkeep
