Sponsored by: CARiD
GM MDI 2 scan tool kit
Old Sep 11, 2025 | 03:43 PM
23cpe3lt's Avatar
23cpe3lt
Default GM MDI 2 scan tool kit
Has anyone purchased a kit?
Old Sep 11, 2025 | 06:59 PM
Mitchell_B's Avatar
Mitchell_B
I own an MDI2 I purchased new from GM
Old Sep 12, 2025 | 01:40 PM
23cpe3lt's Avatar
23cpe3lt
Have you used it on a C8?
Which subscriptions to do trans flush procedure?
Old Sep 12, 2025 | 03:56 PM
Mitchell_B's Avatar
Mitchell_B
https://www.acdelcotds.com/subscriptions
Second option from the top:
GM Light Duty Global Diagnostics 2-GDS 2 (Includes CAN Data Bus Diagnostic Tool)
Covers Chevrolet Light Duty Trucks
With the subscription, there is software you'll download and install on your laptop. You also need to update your MDI-2 to the latest firmware. You should be able to find it here:
https://boschdiagnostics.com/softwar...-mdi-and-mdi-2
There are other less expensive diagnostic interfaces available that are supposed to be able to run on a GDS-2 subscription. One recommended by gsvette is:
Amazon Amazon
You can find the discussion here: https://www.corvetteforum.com/forums...post1609007097
Old Sep 12, 2025 | 05:21 PM
23cpe3lt's Avatar
23cpe3lt
Aha! So a subscription is needed, specifically,
Diagnostics
Which is $64 for 3 days. Kinda sucks. Does this include the service manual access?
Thanks for sharing!
Old Sep 12, 2025 | 05:24 PM
Mitchell_B's Avatar
Mitchell_B
Diagnostics
Thanks for sharing!
The service manual is separate and costs $22 for 3 days.
Old Sep 12, 2025 | 11:13 PM
23cpe3lt's Avatar
23cpe3lt
Is this everything I need?
Do you purchase yearly or 3 day as needed?
Old Sep 13, 2025 | 04:50 PM
JohnStuttle's Avatar
JohnStuttle
Do Not Quench The Spirit
St. Jude Donor '13,'19 thru '26
I have the Foxwell NT710 and it will perform rhe flush and leak test.
Foxwell NT710
Old Sep 14, 2025 | 03:02 PM
Mitchell_B's Avatar
Mitchell_B
That's it. The duration of the subscription you purchase is up to you.
Old Sep 14, 2025 | 06:08 PM
breecher_7's Avatar
breecher_7
Foxwell NT710
I do as well, works perfectly. You don’t need an MDI 2 for this.
Old Sep 17, 2025 | 11:34 AM
kromdom's Avatar
kromdom
Good info here re NON-MDI2 options for '23 and later C8s:
https://www.corvetteforum.com/forums...scan-tool.html
To GM MDI 2 scan tool kit
