Sponsored by: CARiD
C8 intermittent lurching/jerking
Old Oct 3, 2025 | 05:12 PM
rrussell's Avatar
rrussell
Default C8 intermittent lurching/jerking
My 2021 Stingray has a problem in that it sometimes drives rough and has a slight lurching, jerking, or hesitation. It is fine at wide open throttle. At first I thought it was bad gas, but the problem has persisted for 2 months (3 week vacation in July in a Bronco). I took it to the local dealer that I purchased from and the tech read a code and decided to replace the auto tranny sensor. That did not solve the problem and they appealed to GM tech support for suggestions. They have not responded and my C8 is just sitting at the dealer service dept. Have other C8 owners experienced this issue or have a suggestion?
Old Oct 3, 2025 | 07:09 PM
rrussell's Avatar
rrussell
GM tech finally responded with 2 software updates. Supposedly fixed. It will learn my driving for the first 15 trips or so.
Old Oct 4, 2025 | 11:44 AM
JimB.'s Avatar
JimB.
Hopefully that will fix the problem. Let us know.
Old Oct 5, 2025 | 08:42 AM
99vetteran's Avatar
99vetteran
I just bought my 23 and when I was sitting at a stop light it felt strange like it was trying to lurch or something like that. Its only happened on time.
Old Oct 6, 2025 | 09:59 AM
Andybump's Avatar
Andybump
What sensor was replaced? The transmission has a bunch of internal sensors - and its not clear that any of them can be replaced.
Old Oct 6, 2025 | 10:13 PM
TEvans's Avatar
TEvans
Default Everyone Read This!!!!
SEE TECH SERVICE BULLETIN 22-NA-080.
The Bulletin involves the Camshaft Actuator Magnet which helps control the time and cycling of the camshaft. It can stick and throw off the timing resulting in shaking, shuddering, and jerking of the car at low speeds. At high speeds the engine will shudder slightly. The telltale sign at high speed is the Tach needle bouncing instead of holding steady.
The dealer can run a test with the Scan Tool to determine if the actuator is sticking. The Bulletin has a "normal" graph shown in it. If the actuator is off by more than 3 degrees, it must be replaced. THAT involves dropping the engine! Yes, $8000 cost for a cheap $30 part.
Bulletin Attached.
File Type: pdf
Old Oct 7, 2025 | 09:25 AM
Andybump's Avatar
Andybump
Bulletin Attached.
Surprising to me that it states that a normal fluctuation could be up to 4 degrees. The image of the graphs is blurry and the vertical scale is difficult to read. Looks like it might be a logarithmic scale? But it looks like the normal fluctuation line is mostly 1 (degree?) or less.
To C8 intermittent lurching/jerking
