Sponsored by: CARiD
Replacing Z51 brake pads?
Old Oct 12, 2025 | 06:36 PM
rmiked's Avatar
rmiked
Default Replacing Z51 brake pads?
I watched a Paragon Performance Utube on replacing the brake pads. The technician compressed the pistons using a tool and didn’t open the bleeder valve. Is this ok? I read in another article that a scan tool might be needed to deactivate the brake boost system and that pushing fluid backwards can possibly damage the ABS unit. Sounds complicated. For you guys that have replaced your pads, is the Paragon method acceptable?
Old Oct 12, 2025 | 06:44 PM
Mark9's Avatar
Mark9
I disconnect the battery and just push the old pads back toward the caliper with a couple of screw drivers. I've done this 8 or 10 times thus far as I burn through pads on the track fairly quickly. Nothing special needed to replace pads or even to bleed (although some will say you need a scan tool to get the fluid out of the ABS module when bleeding. I bleed at least once a year prior to track season and don't have any issues.
Old Oct 13, 2025 | 10:56 PM
Ryan-TN's Avatar
Ryan-TN
3rd Gear
Just make sure you disconnect the battery but there is no issue compressing the pistons. This is standard on any pad replacement. The ABS module will not be activated during the process based on what I have found. The scan tool is used to active the ABS module when bleeding the brake system or doing a flush to move the fluid through the ABS module. While beneficial not required when bleeding. The pressure method or two man method will work just fine when you choose to take that project on but as to the pads you will be fine.
Old Oct 15, 2025 | 01:33 PM
davanz's Avatar
davanz
What is new about the C8 that requires the battery be disconnected to change pads? I'm not doubting it, I just need enlightenment. The latest model cars I have changed pads on were my 2019 C7 and 2019 Mustang, where I just pushed the caliper pistons in enough to slide in the new pads. No problems. I have just bought a new 2026 Z51, and need to know things like this.
Old Oct 15, 2025 | 01:50 PM
RKCRLR's Avatar
RKCRLR
The C8 has electrically operated brake boost and ABS. The system can be triggered by certain events and self checks. The system could inadvertently operate while the pads are out and push out the pistons, pinch fingers, etc. Also, the system can get confused and cause a brake system code and put it into a limp mode.
Old Oct 15, 2025 | 02:11 PM
davanz's Avatar
davanz
Thanks, that opened my eyes and it is easy to understand the potential problems. An unintended brake application could lead to injury, a mess to clean up, and a need to rebleed the system. Not a consideration with engine vacuum systems.
Old Oct 15, 2025 | 09:58 PM
Kevin93's Avatar
Kevin93
A couple of additional tips (learned the hard way):
  1. Whether or not you kill the battery, no matter what you do, be sure pump the brakes HARD before starting car or you’ll get to limp mode.
  2. if you do get into limp mode, don’t sweat it. As posted by another member, just a) hold down start button with for off brake (ie don’t start engine) for 20-30 seconds until all electronics on, b) hold brake pedal down until it stops clicking, c) foot off brake, d) shut down power, e) start normally. If a residual CEL, can clear with BlueDriver.
  3. Motive power bleeders make the bleeding job really quick, which I do without filling the container so easier cleanup. But, if you do at the same time as pads, depressurize before yanking pads or the pistons will shoot out and leak. Obvious in retrospect…
Old Oct 16, 2025 | 10:08 AM
RKCRLR's Avatar
RKCRLR
As stated above, it is better to have the brakes hard before you reconnect the battery. It's sort of like putting your car under anesthesia before you do surgery.
Another tip - roll down the driver's side window before you disconnect the battery. That way you can reach in to release the manual door latch to get in and pump up the brakes.
Old Oct 19, 2025 | 12:49 PM
Sledge Hammer's Avatar
Sledge Hammer
Good tip.
Old Oct 19, 2025 | 04:14 PM
w4rmk's Avatar
w4rmk
I replaced my factory Z51 pads with Power Stop Ceramic pads a few weeks ago. I disconnected the battery before I started and used the tool to compress the pistons. The entire job went smooth and I had no issues. I did pump up the brake pedal before I reconnected the battery. I didn't get any errors/codes. I did the burn-in process outlined in the instructions that came with the pads. I don't notice any drop in stopping power and all the squeaking I was getting from the factory pads is now gone. Couldn't be happier!
Amazon Amazon
Amazon Amazon
Old Jan 3, 2026 | 12:46 PM
NealB's Avatar
NealB
Originally Posted by Ryan-TN
Just make sure you disconnect the battery but there is no issue compressing the pistons. This is standard on any pad replacement. .
Disconnect the negative terminal only?
Old Jan 3, 2026 | 01:34 PM
Mark9's Avatar
Mark9
Yes.
Old Jan 21, 2026 | 06:55 PM
wrecker3's Avatar
wrecker3
I Changed My 2023 C8 Z51 Pads to Carbotect Pads and Did Not Disconnect Battery Just Did Not Open The Door !!
Old Jan 21, 2026 | 07:05 PM
Mark9's Avatar
Mark9
Not recommended. You were lucky. The brake system can pressurize at any time which can cause a mess or worse. Always disconnect the battery when doing any work on the brakes.
Old Jan 25, 2026 | 07:03 PM
Beast's Avatar
Beast
Excellent choice in pads over powerstop. Anyone use Hawk ceramic pads?
Old Jan 25, 2026 | 10:15 PM
Mark9's Avatar
Mark9
Although I don’t have any personal experience with them I’ve heard that the dust is corrosive so some degree.
To Replacing Z51 brake pads?
