Sponsored by: CARiD
New C8 breaking period
Old Feb 8, 2026 | 04:11 PM
Dlseaside's Avatar
Dlseaside
1st Gear
Default New C8 breaking period
Hi all,
I'm new to Vet ownership and this forum.
I have a 2026 C8 Stingray. I have about 500 miles on it. I was unaware of the breaking period. In the 500 miles ive driven the car i have not used the paddle shifters, i have only gptten up to about 90 mph once for just a very short period of time. I have not let the rpm get super high, i dont think ive gotten over 4-5K. I have used the cruise control a few times. Have i done any harm to the engine and transmission at this point? Thanks for any suggestions and opinions.
Old Feb 8, 2026 | 04:47 PM
JVi's Avatar
JVi
500 miles for the initial break-in and no racing for the first 1500 miles.
Old Feb 9, 2026 | 12:01 PM
Andybump's Avatar
Andybump
Originally Posted by Dlseaside
Hi all,
If you have not done so, you should download a copy of the 2026 Owner's Manual and read through it. Besides the break in periods of 500 and 1500 miles there are critical maintenance items you need to know about. No aggressive driving, tracking, launch control launches until after 1500 miles. There is this, about the transmission: "The transmission external canister filter must be changed at 12 000 km (7,500 mile) during the break-in period." There is no special operational limit after 1500 miles, but the transmission is still shedding break in debris up to 7,500 miles. You need to change that filter between 7000-8000 miles even if you change it earlier.
Regarding your question about "damage" - what you described will not cause any catastrophic engine failure. I think improper break in might affect drivetrain performance or longevity way down the road. And, there really is nothing you can do about it now. Here is reason given for the break in period in the manual:
"Parts have a break-in period and performance will be better in the long run."
But it is also very specific about not tracking until 1500 miles.
I think you could damage the car (maybe) if you go out and track it, do launches, or very aggressive driving before the break in period. Tracking and track like driving puts a good deal of stress on the transmission - the evidence for this statement is the requirement in the manual to change both transmission fluid and filter every 24 hours of track use. Compare that with the normal requirements for street use - filter at 7500, 22,500, then every 22,500 miles after. Fluid at 45000 miles or at least every three years. Tracking shortens the replacement period for filter and fluid considerably.
Old Feb 9, 2026 | 05:09 PM
ARentz07's Avatar
ARentz07
Your car will be fine if you went to 5k RPM once or twice, but you really should not do that until break-in is done. Consider the fact that some owners don't abide by the break-in period and still have no issues... immediately. Data shows that break-in procedures improve engine longevity, though, and are recommended for good reason.
I second Andybump that your source of truth should be the manual. If you want to take the best care of the car, you should be informed on how to do so.
Old Feb 10, 2026 | 01:53 PM
Orion2011's Avatar
Orion2011
Break in is more for the transmission than the engine. The engines are initially broke in at the factory.
Old Feb 10, 2026 | 02:26 PM
Thunderstealer's Avatar
Thunderstealer
They should break in the transmission as well then, then you could just get in and go
Old Feb 10, 2026 | 02:31 PM
patton's Avatar
patton
St. Jude Donor '09
An added benefit is the owner gets broken in before going WOT ...corvettes don't take kindly to a FNG with a heavy foot and cold tires
Old Feb 10, 2026 | 02:37 PM
ARentz07's Avatar
ARentz07
I have not heard that before. Who said that?
Old Feb 10, 2026 | 04:06 PM
Andybump's Avatar
Andybump
Its both. You won't find anything in the manual explicitly stating the break in period is just for the engine or the transmission specifically - its about the powertrain. The are clues that both the engine and the transmission are in a break in period when new.
The manual say this about the beak in period: "Check engine oil with every refueling and add if necessary. Oil and fuel consumption may be higher than normal." This of course is because the ring and cylinder walls are wearing, as well as other mating surfaces in the engine. We also know that first DCT filter change is at a very short 7,500 miles, because the transmission is shedding more debris during break in.
And there is this statement that seems to say the break in period is about both:
"The new vehicle break-in period should be completed before performing the brake burnish procedure, otherwise damage may occur to the powertrain/engine." Why would burnish procedure be a break in issue? I had to think about that but the procedure involves driving at 60 mph for 10 miles (driving at a constant speed ?).
And this statement that also seems to say its about the engine and powertrain:
"The new vehicle break-in period should be completed before using the launch control feature, otherwise performance will be limited and damage may occur to the powertrain/engine."
And finally this: "The transmission external canister filter must be changed at 12 000 km (7,500 mile) during the break-in period." Which tends to support the idea that the transmission has a long break in.
In any case, taken all together, I think its clear that the break in is about engine and transmission.
To New C8 breaking period
