Sponsored by: CARiD
Blackstone Oil Analysis Feedback
Old Apr 12, 2026 | 10:07 AM
Midwest C6's Avatar
Midwest C6
Default Blackstone Oil Analysis Feedback
Seems OK, any experts have any comments.
File Type: pdf
Old Apr 12, 2026 | 10:34 AM
patton's Avatar
patton
St. Jude Donor '09
blackstone said you are good to go what more ya want.....a lollipop ?
Old Apr 12, 2026 | 10:50 AM
Midwest C6's Avatar
Midwest C6
Nope, as I said just looking for opinion of anything I should concerned about, as I am not an expert.. Thanks for yours.
Old Apr 13, 2026 | 01:00 PM
Bobbo76's Avatar
Bobbo76
Veteran: Canadian Forces
I have some experience in this area but primarily on diesels. I don't measure all of the elements that Blackstone include however the main ones that would indicate engine wear appear remarkably low regardless of the fact that you're tracking the car
I assume you followed their instructions as accurately as possible?
Old Apr 13, 2026 | 01:54 PM
FathomGreen's Avatar
FathomGreen
Cruising
Compared to some engines Iron could be said to be high, (like daily putzing drivers) but if you are using it for Track then it most def is not high at all.
What you really are looking for are Trends. In which require consistent interval samples being sent in to compare from one to the other.
I do Long road trips in my 2011 Charger Pursuit, and typically get an oil sample after a 5,000+ run to look at numbers every year. My first sample I sent in was during a Lifter failure and my iron PPM was 38. Blackstone said it was elevated but not in a "danger zone" when compared to universal averages. However since the repair and even into the 200,000+ mile range my iron PPM remains below 15ppm on avg.
I have used BlackStone for big Diesel Trucks at work, as well as aircraft Radial engines (R1820 and a R1300)
Old Apr 13, 2026 | 03:00 PM
Mitchell_B's Avatar
Mitchell_B
Looks okay for track use. Your viscosity is solidly in the 40 weight range. With 5000 miles, depending on how the car was driven for the majority of the time, your engine is probably still breaking in.
Old Apr 13, 2026 | 04:38 PM
Midwest C6's Avatar
Midwest C6
I did.
Old Apr 13, 2026 | 04:39 PM
Midwest C6's Avatar
Midwest C6
Appreciate the input. Will certainly do again to get trending info.
Old Apr 16, 2026 | 11:23 AM
AZSP33D's Avatar
AZSP33D
One important note in addition to SOAP/Blackstone is that you still want to cut the filter open and look… and look at the drain plug magnet. This is how you discover more serious issues quicker and more definitively than just analyzing molecular level suspended nanoparticles. Serious wear issues versus minor wear trends over units of time/miles and delayed by 3+ weeks of processing time.
Old Apr 16, 2026 | 11:50 AM
Mitchell_B's Avatar
Mitchell_B
This is definitely true. Oil analysis methods are not able to detect particles over 8-10 microns. For perspective, a good oil filter will trap particles above 25 microns. While there is additional cost, I always have a particle test done on my used oil samples as this will tell you the population and size of contaminants in the oil. But, your assertion that doing the basic task of simply looking inside the filter is good practice. On my Z06, I unscrew the oil filter retaining cap and let the oil drain slowly out of the filter, remove the filter and look to see what if anything is in the cap.
Old Apr 17, 2026 | 08:46 AM
Andybump's Avatar
Andybump
What happens if you find those larger particles? If they are there, isn't that an indicator of something more serious than an oil issue? Like an actual mechanical failure of some sort? If under warranty, would a dealer investigate on that basis?
Old Apr 17, 2026 | 09:33 AM
Mitchell_B's Avatar
Mitchell_B
Anything you find in your oil is not an oil issue - it is an engine issue. Things you might find that would not necessarily show in an oil analysis are broken chain guides, valve train broken parts, broken gaskets, ingested foreign debris, sand from casting porosity….
I would collect and save a sample of debris if found and get your service department to document and address it. They might tell you no repair action is needed and then the ball is in your court.
Old Apr 18, 2026 | 04:24 AM
superramvette2's Avatar
superramvette2
Tough crowd. Looks good to me , better than mine actually. (viscocity was low, little extra fuel I think). Thanks for sharing, nice to see others reports.
To Blackstone Oil Analysis Feedback
