Sponsored by: CARiD
Brake judder and Brake pads
Old Apr 14, 2026 | 06:14 PM
diguy's Avatar
diguy
Cruising
Default Brake judder and Brake pads
Thanks to all who have offered explanations for brake judder. I have a 2022 C8 Z51 with stock calipers and Brembo OEM pads. I have judder during track use that increases with increasing laps but does not occur during street driving. What I am looking for is the experience of those of you who also have HPDE induced judder with OEM pads. If you tried non-OEM pads, please reply with ID of pad tried and if it reduced/eliminated judder. I want to see if pad choice will help before investing in new rotors/calipers, etc. There are a lot of pad options so I am hoping the Forum's knowledge will narrow down my options.
Old Apr 14, 2026 | 07:19 PM
patton's Avatar
patton
St. Jude Donor '09
explain a little more the symptoms .......does the anti lock brake warning come on the dash when it happens , does the steering wheel vibrate under braking [front brakes] or do you feel it in your seat [rear brakes ] . Warped rotors can be more pronounced hot high speed stops
Scott_Wisconsin's Avatar
Scott_Wisconsin
Funny you should ask!
I have a post somewhere last year where I went though all sorts of pads, rotors, even changed the front wheel bearings trying to figure this out! Ultimately this year, a few weeks ago, I decided to just trade it in for a Z06...
Here's my old post: https://www.corvetteforum.com/forums...on-issues.html
However bottom line, from what I could gather is that the ABS is very sensitive, and unless you are in RACE 2, where almost all "nannies" are off, ABS is very aggressive. Coming from a C7 Z06 track only car, it's a world of difference in braking with the C8.
I only track my car, so of course any street driving there is no "judder"...
I even, over black friday last year purchased AP racing calipers / rotors to change out for this year / season, but instead went for the Z06, so never got to install / use the AP racing to see if those helped.
I had tried stock rotors / pads, Girodisc rotors, EBC rotors, DTC pads, nothing helped.
Old Apr 14, 2026 | 08:04 PM
diguy's Avatar
diguy
Cruising
No anti lock light, yes steering wheel vibrates, not much seat vibration. Changed front rotors, worked for a few sessions, then judder again.
Old Apr 14, 2026 | 08:09 PM
Mark9's Avatar
Mark9
I've tracked my '23 z51 with stock rotors and pads and with girodisc rotors and stock pads. No judder in 30+ track events. I've since switched to Carbotech xp12s but haven't been on the track yet. I suspect uneven pad transfer on your rotors. I'd DA them with 80 grit and re-bed the pads.
Old Apr 14, 2026 | 08:11 PM
Mark9's Avatar
Mark9
How did you bed the pads? Per the track guide?
Old Apr 14, 2026 | 08:16 PM
diguy's Avatar
diguy
Cruising
I sand the rotors with 80 grit each time I change pads. I bed the pads as described in track guide. I suspect uneven pad transfer too. Perhaps the stock pads do not hold up well to track-based brake heat.
Old Apr 15, 2026 | 05:28 AM
Scott_Wisconsin
The ABS light will not come on... See my post here where you have to examine the PDR data with Cosworth toolbox and see where the ABS kicks in:
https://www.corvetteforum.com/forums...post1608993371
To Brake judder and Brake pads
