Sponsored by: CARiD
Transmission Failure 24 C8 Stringray
Old Apr 23, 2026 | 12:54 PM
Iswearitsalambo's Avatar
Iswearitsalambo
3rd Gear
Default Transmission Failure 24 C8 Stringray
I thought I'd make a thread for tracking overall issues, this is purely a knowledge post for others that I will update as my transmisison is being replaced.
Hey folks, I bought a brand new c8 stringray in June of 2024, followed proper break in procedure, oil change and transmission filter changes done at correct intervals. Otherwise just enjoyed the car over the last two years, I put about 20k miles on her.
Last Sunday the car suddenly begins skipping even gears(2,4) with a notice saying "idle creep disabled". I dropped it off at the dealership from where I bought the car figuring I need a transmission change. I was debating doing mods like a catback, but thank god I didn't. Didn't want to give Chevy a single inch in case something happened.
Quick Question:
Do I have any options with Chevy that I should resonably pursue? E.G when my gt350 engine had to be replaced I was able to get a free extended warranty, etc etc
Vehicle Details:
2024 C8 Stringray
Miles: 19500
Modifications: zero
Diagnostic Information
  • Document ID: 5507621
  • Vehicle Model: Chevrolet Corvette (indicated on the diagnostic screen)
  • DTC (Diagnostic Trouble Codes): P0846 – P0849
  • Component Tested: T12 Automatic Transmission / Transmission Fluid Pressure Sensor 2
Test Configuration
  • Connector: T12 Connector at the transmission
  • Test Points: * Signal Circuit Terminal: 12
    • 5V Reference Circuit Terminal: 20
  • Equipment Used: 10-amp fused jumper wire (the manual specifies 3-amp, but a 10-amp was utilized in the demonstration).
Diagnostic Results
  • Required Parameter: Greater than 4.8 V
  • Measured Value: 5.5 V
  • Conclusion: Since the measured voltage exceeded the threshold, the manual dictates: Test or replace the T12 Automatic Transmission.
Old Apr 23, 2026 | 03:07 PM
patton's Avatar
patton
St. Jude Donor '09
you can ask for a freebee anything , they might throw something at you , try something on the exhaust that gm sells .....myself i would settle for a loaner car
Old Apr 23, 2026 | 03:18 PM
thebishman's Avatar
thebishman
If your even gears are gone, then suspect a failed Valve Body. Dealers are now replacing these without replacing the whole transmission, so you should be good to go soon after the parts are in. Hopefully!
Old Apr 23, 2026 | 03:54 PM
frankbicknell's Avatar
frankbicknell
Just an FYI. There is a big difference between 3 and 10 amps. 10 amps can do A LOT of electrical damage before it blows vs 3 amps.
To Transmission Failure 24 C8 Stringray
