C8 Z06 Discussion General Z06 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
Randomness....
Old Sep 5, 2021 | 12:12 AM
WalterSobchak's Avatar
WalterSobchak
Stingray has brake ducts in the same location as Z06, just bigger on the Z06.
Old Sep 7, 2021 | 09:27 AM
jim2092's Avatar
jim2092
Veteran: Marine Corps
St. Jude Donor '08
Best start saving now to replace the tires on that ZO7. Ouch.
Old Sep 7, 2021 | 10:37 AM
vndkshn's Avatar
vndkshn
Originally Posted by yz250fPilot
Check out the weight transfer to the passenger with the driver-rear tire coming up off the ground...
That is one reason why to have wide rear tires!
Well, it's also been pointed out that the rear suspension of the C8 creates negative camber as the tire move down (as in this shot) versus maintaining the same camber. So as the driver side is unloaded and the car shifts to the passenger side, grip is actually removed more than it should because of suspension geometry. So that wider rubber may be just to compensate for compromised suspension geometry.
