C8 Z06 Discussion General Z06 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
Front Lift
Old Nov 11, 2021 | 04:28 PM
GmdVT's Avatar
GmdVT
Default Front Lift
So I am pretty much getting the front lift, but how screwed am I here from my garage? (Although to be honest in pics it doesn't look that bad maybe it looks worse than it really is when driving up and down it)
This guy seems to get in and out just fine?
Old Nov 11, 2021 | 04:29 PM
GmdVT's Avatar
GmdVT
Also to add, I no longer have the C6 in my avatar so I have no reference to how that would clear this that is a different garage pictured
Old Nov 11, 2021 | 04:35 PM
Reep's Avatar
Reep
It seems from the picture of the Porsche you should have no problem with the lift. If it's even close you have a wide enough entrance to angle in addition to the lift. That should easily clear it.
Old Nov 11, 2021 | 04:40 PM
GmdVT's Avatar
GmdVT
Yeah I am probably being overly paranoid but you're right that overhang on the porsche is a lot and if it does fine then I should be ok
Old Nov 11, 2021 | 04:44 PM
marknagy13's Avatar
marknagy13
There are special guards you can get to put under the front splitter which protect the cars paint. Not too expensive
Something like this
https://x-ph.com/acexxon-heavy-duty-...xoCt2wQAvD_BwE
Old Nov 11, 2021 | 04:48 PM
GmdVT's Avatar
GmdVT
I'm debating not even getting the splitter, although might be better to let it take damage and not the body panel
Old Nov 11, 2021 | 05:25 PM
Racer X's Avatar
Racer X
Any way to measure the angle? Or you could measure the height of the drop and the length of the drop to the level floor and calculate it. There are published angles of approach and departure for the C8 with and without the lift. The Z06 might be different but would unlikely be more than the base car.
Old Nov 11, 2021 | 05:34 PM
Blvdbrawler's Avatar
Blvdbrawler
I think you will be okay. The lift coupled with an angled entrance/departure (going slowly) and you will be just fine.
Old Nov 11, 2021 | 05:46 PM
Sin City's Avatar
Sin City
2020 C8 of the Year Finalist - Unmodified
I have a similar problem. Even with the lift I have to go sideways. You get used to it.
To Front Lift
