C8 Z06 Discussion General Z06 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
Ground Effects option question.
Old Aug 2, 2022 | 10:03 PM
patjza80's Avatar
patjza80
Default Ground Effects option question.
Hey guys sorry if this has been asksed.
I'm looking at the:
CFV: Carbon Fiber Visible Ground Effects
and
CFZ Carbon Fiber, Carbon Flash Painted Ground Effects
I'm considering one of these two potentially but had this question if anyone knew. Playing around with the visualizer tonight, it appears the shape of the side shirts do not change, and you end up getting a different lip (yes i know the material changes).
Can anyone confirm that? If that is the case, I'll wait for paragon to put out a nice lip and save the money.
Old Aug 2, 2022 | 10:14 PM
range96's Avatar
range96
My understanding is that they share the shape and material, the only difference is that the Carbon flash is painted (to cover visual imperfections in the carbon fiber).
Old Aug 2, 2022 | 10:59 PM
patjza80's Avatar
patjza80
Awesome, thanks man!
Old Aug 3, 2022 | 10:30 PM
JockItch's Avatar
JockItch
Honestly if i was considering the Carbon Flash version of the optional splitter and side skirts on a non-Z07, I’d probably just hold off and wait for a much cheaper replica version from the aftermarket.
Old Aug 3, 2022 | 10:54 PM
smithers's Avatar
smithers
That's probably what I'm doing. I figure ACS or someone will make one that is a lot less than $3,000. They can make it out of fiberglass for all I care.
Old Aug 4, 2022 | 07:23 AM
JockItch's Avatar
JockItch
Agreed… and a lot less painful to repair/replace should it get damaged.
Old Aug 4, 2022 | 11:21 AM
_Aviator_'s Avatar
_Aviator_
Aviator in Michigan
ACS Composites in Carbon Flash
Very pleased with the quality
To replace the molded textured plastic OEM
Just received my ACS shipment today. Perfect finish and match. Very pleased with the quality of this piece.
Old Aug 4, 2022 | 01:43 PM
_Aviator_'s Avatar
_Aviator_
Aviator in Michigan
Plastic OEM removed
ACS splitter installed
Old Aug 4, 2022 | 07:20 PM
C8UR911's Avatar
C8UR911
I wonder how much purchase and install would end up being, probably close to $3000 anyway? I could do the install myself but I have no lift, would have to buy some kind of ramps, probably a rivet gun and God only knows what else…
Old Aug 4, 2022 | 07:49 PM
JockItch's Avatar
JockItch
I’d sure hope not, most would just order OEM if so. I’d guess around half of that.
Old Aug 4, 2022 | 10:30 PM
patjza80's Avatar
patjza80
Thanks exactly what I was thinking.
To Ground Effects option question.
