C8 Z06 Discussion General Z06 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
what does the Z07 package include??
Old Dec 19, 2022 | 02:08 PM
Carl44's Avatar
Carl44
Default what does the Z07 package include??
Am i missing something it looks like the Z07 package is just the ceramics and R compound tires? Thats all i can find on the configure rater ..thanks carl
Old Dec 19, 2022 | 02:25 PM
z28lt1's Avatar
z28lt1
CC Brakes, the tires and a switch from FE6 to FE7 suspension which changes spring and anti-roll rates. Forced take of the high aero option.
So, just what you mentioned and suspension changes. It's only $500 more than the CCB on the Z06, so they aren't loading it with other stuff.
Old Dec 19, 2022 | 03:01 PM
Jeff V.'s Avatar
Jeff V.
Ceramic brakes, FE7 suspension, Cup2R tires, and you're required to pick one of the aero packages.
Z07 Performance Package, includes (J57) 4-wheel
antilock, 4-wheel disc, carbon ceramic brakes, (J6D)
Dark Gray Metallic-painted calipers, (FE7) Z07
suspension with Magnetic Selective Ride Control and
(XFS) 275/30ZR20 front and 345/25ZR21 rear Michelin
Pilot Sport Cup 2 R ultra performance tires
1 - Requires (CFZ) Carbon Flash-painted carbon fiber
ground effects and (T0F) Carbon Flash-painted carbon fiber
high wing rear spoiler or (CFV) visible carbon fiber ground
effects and (T0G) visible carbon fiber high wing rear spoiler.
Old Dec 19, 2022 | 06:04 PM
AzDave47's Avatar
AzDave47
$19-21K cost of stuff to customers.
Old Dec 19, 2022 | 06:36 PM
JockItch's Avatar
JockItch
Unavailability.
Old Dec 19, 2022 | 06:43 PM
SharkDiverZ06's Avatar
SharkDiverZ06
That's a good one!
Old Dec 19, 2022 | 08:18 PM
NakedDave's Avatar
NakedDave
Originally Posted by JockItch
Unavailability.
HA! Winning
Old Dec 19, 2022 | 09:48 PM
Higgs Boson's Avatar
Higgs Boson
What the Z07 comes with that you can't get a la carte:
Underbody air guide strakes
8% stiffer springs
track oriented tires
everything else (ceramic brakes, big wing, etc) is required to buy to access the above items
if those items are not important to you, the cermic brakes, carbon wheels and wing/splitter can all be ordered individually.
Old Dec 19, 2022 | 10:03 PM
JockItch's Avatar
JockItch
dive planes under the headlights
8% stiffer springs
You can still get the dive planes if you get the optional aero with the CCB’s. Ends up being around $500 less than Z07 with aero. Lose the stiffer suspension and Cup2R’s, which some might prefer… although I suspect most will opt for Z07 even if they don’t want the tires and prefer a softer suspension.
Old Dec 20, 2022 | 12:44 AM
Higgs Boson
yeah i think you're right, edited my post
Old Dec 20, 2022 | 12:52 AM
U-Boat Commander's Avatar
U-Boat Commander
1st Gear
Does anyone know if it's possible to replace the high wing on the Z07 package with the more mundane Visible Carbon Fiber Spoiler option? Put another way, does the Visible Carbon Fiber Spoiler slot into the same openings as the Z07 high wing? I'm assuming this would be done after delivery as I understand the factory won't do it. I like everything about the Z07 package except the boy racer wing.
Old Dec 20, 2022 | 03:04 AM
First Vette Z06's Avatar
First Vette Z06
They don’t mount the same, so you would likely have to drill holes for the low spoiler to mount, but it would be easier to hide the big wing mounting holes with the low spoiler. It’s harder to go from low spoiler to the big wing as you would have to fill the exposed holes.
Alternatively, I’m sure there will be an aftermarket option that’s lower but can mount in the big wing holes. Just might have to “suffer” with the big wing for a bit until someone comes out with one.
To what does the Z07 package include??
