1600 miles in and 2 problems (not counting the typical GM body panel fitment).
1) At 1500 miles the rear hatch quit working with the button at the back. It still works with the key fob and the door switch.I downloaded the manual online and no where does it show a fuse or relay for the rear hatch.
Does anyone know what fuse or relay controls it?
2) At 1600 miles the front trunk quit working with the remote key for. Works with the front button and the door button. In the manual it shows a fuse and 2 relays. I have to check them out but has anyone had this experience?
I'd be surprised if there's more than one fuse for the rear hatch, or the frunk lid, so if it works from the door switch but not the rear switch or key fob I doubt it's a fuse.
Reset the computers. Search for instructions on the forum. something about leaving the door open for 90 seconds and other stuff.
Or disconnect the battery for 30 seconds.
It is possible one of the computers that controls something is glitched, or one of 1000 connectors is loose.
