C8 Z06 Discussion General Z06 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
Speed limit exceeded
Old Aug 14, 2023 | 01:49 PM
zrracer's Avatar
zrracer
St. Jude Donor '11, '14
Default Speed limit exceeded
How do I turn this off.
I can't find it in the failure to communicate Manuel.
shows in heads up
wether cruise is on or off..
TIA
Robin
Old Aug 14, 2023 | 02:11 PM
ATC399's Avatar
ATC399
Dont speed....my bad way to easy...no clue...good luck OP
Old Aug 14, 2023 | 03:19 PM
turbotuner20v's Avatar
turbotuner20v
I would assume there's an option for 'read speed limit' under driver assist or camera settings. If the camera doesn't read the speed limit then it won't know to flash the warning.
Old Aug 14, 2023 | 03:41 PM
Kracka's Avatar
Kracka
It pulls the speed limit info from the navigation system. There's a setting buried in the menus somewhere to enable/disable this, I've seen it, I just don't remember where.
Old Aug 14, 2023 | 03:58 PM
Ragtop 99's Avatar
Ragtop 99
Here is this cryptic instruction from the manual:
The Speed Warning display allows the driver
to set a speed that they do not want to
exceed. To set the Speed Warning, press the
thumbwheel when Speed Warning is
displayed, or press the thumbwheel on the
main view to set the speed value. Scroll to
adjust the value. Press the thumbwheel to
set the speed. Once the speed is set, this
feature can be turned off by pressing the
thumbwheel while viewing this page. If the
selected speed limit is exceeded, a pop-up
warning is displayed with a chime.
That would suggest it is buried in the controls in the DIC.
One other possibility is you may have the teen driver speed warning turned-on. Settings/vehicle/teen driver.
You'll probably have to hunt through all the menus, if that is not one of those two.
hdrider1's Avatar
hdrider1
It's in the vehicle settings menu. Open the menu up on the info screen and scroll through the options til you find it.
Old Aug 15, 2023 | 01:49 PM
zrracer's Avatar
zrracer
Thanks guys.
I will try your suggestions and report back.
maybe help others.
Old Aug 15, 2023 | 01:55 PM
westsdad's Avatar
westsdad
Caution exceeding the speed limit as it causes transmission and engine leaks, ticking, and failures!
Old Aug 15, 2023 | 02:04 PM
zrracer's Avatar
zrracer
Thank you 2 posters for the stupid non helpful comments.
I personally fell that if members are asking for help yOu should;
help
or not
Being stupid and adding stupid comments does not reflect well on us users who use this forum as an place for knowledge, camaraderie and and learning.
IMHO
Old Aug 15, 2023 | 02:07 PM
zrracer's Avatar
zrracer
Ragtop,
thanks for the idea.
your suggestion is for the speed warning. It's different than the you have exceeded the posted speed.
I am going to look in the teen driver section next trip out.
thks
Old Aug 15, 2023 | 07:30 PM
ATC399's Avatar
ATC399
Oh Francis....
Old Aug 15, 2023 | 07:38 PM
zrracer's Avatar
zrracer
[QUOTE=ATC399;1606945579]Oh Francis....[/I
thank you for the useless comment
You trolls should start your own forum. Think if the useless fun u can have👍👍👍👍👍👍👍
To Speed limit exceeded
