C8 Z06 Discussion General Z06 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
Need advice- check engine light
Old Nov 12, 2023 | 11:35 AM
Vettefanatic21's Avatar
Vettefanatic21
Cruising
Default Need advice- check engine light
Check engine light came on on my z06 at 645 miles. Obviously very frustrated and worried. Do I take it to my in town dealer that I don't trust at all but should have a corvette mechanic (they sell new vettes) or do I risk driving it 110 miles to the closest dealership that I trust to actually work on it? Car seems to be running okay.
Old Nov 12, 2023 | 11:44 AM
Millerrock's Avatar
Millerrock
if it was me, I’d find someone with a scanner and have them scan it. I don’t trust dealers, but we are married to them unfortunately cause of the warranty. Corvette tech doesn’t mean anything, I see how dealers work being in one for almost 30yrs, it’s who ever is available for the job, with some years behind them. The dealer will tell you anything then some 18yr old lube tech is scanning your car and asking for help what to do, see it all day long.
Have the car scanned, see what it is, if the light is flashing it’s not a good idea to drive it, but if it’s on solid, there won’t be any harm done, if the eco sees harm it will put the car into limp mode and give reduced power.
Old Nov 12, 2023 | 12:08 PM
Jwalker3rd's Avatar
Jwalker3rd
Banned Scam/Spammer
Id take it to the dealership you trust to work on it. Since you got a CEL, I would scan your car before driving it 110 miles. Goto your local mechanics and have them do it. Or goto one of those chain automotive part stores. They will do it for free.
Old Nov 12, 2023 | 01:05 PM
Vettefanatic21
Cruising
So I cycled on off for about 10 minutes 3 different times and the CEL is now off. I am hoping this means this hopefully isn't serious issue? I'm assuming still take it to a place to be scanned?
Old Nov 12, 2023 | 01:24 PM
JABCAT's Avatar
JABCAT
If you hit your Onstar button they can tell you what the codes were
Old Nov 12, 2023 | 01:55 PM
Vettefanatic21
Cruising
I tried that. They said they couldn't see any codes showing.
Old Nov 12, 2023 | 01:59 PM
Millerrock's Avatar
Millerrock
it will come back, get it scanned. Key cycles will do this
Old Nov 12, 2023 | 07:18 PM
BearZ06's Avatar
BearZ06
St. Jude Donor '09 thru '17,'22 thru '26
Autozone and others will check it free for you if it comes back.
Old Nov 13, 2023 | 11:09 AM
Vettefanatic21
Cruising
Scanned it and the code that came up was U1611- loss of communication with engine control module on CAN BUS 2. Called dealer and they said if the light is off and car running normally it will be really hard to figure out with a history code but to bring it in if it happens again. Fingers crossed
Old Nov 14, 2023 | 08:30 AM
mcynet's Avatar
mcynet
Default Onstar?
call onstar and have them tell you the code and email the report free with a new vette
To Need advice- check engine light
