C8 Z06 Discussion General Z06 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
Check Engine Light...
Old Jan 2, 2024 | 07:49 PM
Scoz's Avatar
Scoz
Default Check Engine Light...
My Z06 has 750 miles and has been parked for the winter. Today I had to move it to the other side of the garage, it hadn't been started in 4 to 5 weeks. While I was moving it I noticed the Check Engine light was on. On-Star sent the codes; ECM-Engine System P0301, P0307 and P0300. They of course said to call the dealer for service.
Has this happened to anyone else or have any insight?
Thanks,
Steven
Old Jan 2, 2024 | 08:45 PM
range96's Avatar
range96
Insufficient fuel in cylinders 1 and 7.
Old Jan 2, 2024 | 10:42 PM
383vett's Avatar
383vett
Charge the battery.
Old Jan 3, 2024 | 07:43 AM
Scoz's Avatar
Scoz
I had the battery tender plugged into it while it was parked.
Old Jan 3, 2024 | 11:02 AM
Z0HS1CK's Avatar
Z0HS1CK
I been saying this isn’t the car you should let sit.
Old Jan 3, 2024 | 11:18 AM
ls1wolf's Avatar
ls1wolf
How long did you let it idle for? Did you let the oil temp get above 160 every time? Are you sure the tender is even working?
Old Jan 3, 2024 | 11:28 AM
RD-1's Avatar
RD-1
That is a ridiculous statement, some people like myself have to store cars due to weather conditions. My cars sit for up to 6 months and are always on a battery tender, never had any issues in over 20 years. Now if your car is parked outside and pests and rodents get to the wiring, that's another story. Also water damage can also play it's part into damaging the electronics.
To the OP's issue, when you have the opportunity just drive the car around for a while and see if the MIL goes away. If not simply take it into the service department.
Old Jan 3, 2024 | 11:45 AM
Z0HS1CK's Avatar
Z0HS1CK
You never had a c8z in the past 20 years lol
thats what I’m saying. This is new territory for most of us aside from the very few who got their cars early 2023.
with how finicky these cars are, I’m sure the cold weather doesn’t help with these gremlins.
not saying to drive it during a blizzard but those storms last a day, streets get plowed, then it’s time to drive.
Old Jan 3, 2024 | 11:48 AM
Scoz's Avatar
Scoz
I did consider the battery when I was trying to figure it out. I did wonder if taking it for a drive and letting the alternator recharge to battery would make a difference or clear the codes.
Old Jan 3, 2024 | 11:51 AM
RD-1's Avatar
RD-1
I never said I had a C8 Z06 in the past 20 years, I will find out this spring since my car has been parked since Oct 2023. I call BS on your theory.
Old Jan 3, 2024 | 11:56 AM
RD-1's Avatar
RD-1
I wasn't referring to the battery state of charge, if the tender is on and functional the battery state of charge should be fine. Now a battery could have a bad cell which could cause issues. Sensors can be finicky such as O2 sensors which can get moisture build up, this can throw a check engine light due to improper fuel mixture. Now you take that same car for a good run and get some heat into it and bingo the light goes out and the problem is solved.
Old Jan 3, 2024 | 11:58 AM
Z0HS1CK's Avatar
Z0HS1CK
I’m not saying you did In literal terms.
I commenting on your “never had an issue the past 20 years “ statement.
this c8z, with all the known and whacky issues, isn’t something to take lightly.
I hope your car doesn’t develop issues this winter. I don’t wish that upon anyone.
but I will bookmark this post until spring time when we see new threads about issues or potential issues from taking cars out of storage.
Old Jan 3, 2024 | 12:04 PM
RD-1's Avatar
RD-1
I never said you did.
We are at the mercy of the machine, we can't control the outcome. This isn't like a baby and you didn't feed it, burp it or change it's diaper. It's a car if it can't sit for an extended period of time without having issues then it's a POS. One would think more would go wrong with revving the snot out of it at 8600 rpm. I know most people don't like taking the car to the dealer myself included but we have no choice.
Old Jan 3, 2024 | 12:15 PM
Z0HS1CK's Avatar
Z0HS1CK
No I totally agree. Listen I have a z06 and I pray each day I start it it’ll be just fine just like my c7z of 7 years with ZERO issues and never a cel EVER.
but this car seems different. The engine is unfamiliar to us. This car itself is unfamiliar to us.
everything we read so far has been pretty shaky.
So that’s why I feel like because of this under normal circumstances, the cold weather won’t help with these issues and hiccups, it’ll only amplify it.
Old Jan 3, 2024 | 12:22 PM
Vega$Vette's Avatar
Vega$Vette
Drive it up to temp and get a few cycles on it.
I would also consider using a code reader to clear the codes and/or disconnecting the battery for about 10 minutes before taking it to a dealer.
Old Jan 3, 2024 | 12:31 PM
Jwalker3rd's Avatar
Jwalker3rd
Banned Scam/Spammer
LOL
Your Tesla will have more recalls before any issues arise letting Z06 sitting for 6 months. And you drive that all the time, no?
My C7Z has over 30K miles and sits longer now since I bought my C8Z, and it starts every time. Wether it sits 3 months, or 6 months.
My trackhawk sat idle in my insulated garage with a mini split for almost a year. Guess what? Took it out over the holidays, put 500 issue free miles on it.
looking forward to your April/May post..👍
Old Jan 3, 2024 | 12:32 PM
Rapid Z's Avatar
Rapid Z
Most likely clogged injectors take it out for a spin then put it through several start stop cycles to see if the codes clear
To Check Engine Light...
Old Jan 3, 2024 | 12:33 PM
Jwalker3rd's Avatar
Jwalker3rd
Banned Scam/Spammer
Stay off the public forums and Facebook for a year and enjoy the car. 99% of us have zero problems with our Z06s..
Old Jan 3, 2024 | 01:12 PM
Z0HS1CK's Avatar
Z0HS1CK
Originally Posted by Jwalker3rd
LOL
I had my tesla over a year with zero issues. Never had a check engine light neither
but I been reading many threads about new z06’s getting theirs though lol
ill be here in spring though
Old Jan 3, 2024 | 01:14 PM
Z0HS1CK's Avatar
Z0HS1CK
I have 1600 miles on my z06 already. Zero issues.
but I’m not gonna let it sit. Because I don’t want issues
