C8 Z06 Discussion General Z06 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
Track mode
Old Feb 16, 2024 | 07:13 PM
jazvet's Avatar
jazvet
Veteran: Marine Corps
Default Track mode
Can my 24 Z06 be driven in track mode all the time or is it not good for tranny and motor ?
Old Feb 16, 2024 | 07:58 PM
jswatek's Avatar
jswatek
I'm no expert but, I think track mode only changes the settings of stability control and traction management. So no, it won't hurt anything except maybe you and the paint work if you hit something! lol
Old Feb 16, 2024 | 08:08 PM
Bluehinder's Avatar
Bluehinder
Not good for your wallet after getting bail money if driving in track all day on the street.
Old Feb 16, 2024 | 08:17 PM
Bald Guy's Avatar
Bald Guy
Take the track mode to the track. Healthy for you and the car.
Old Feb 16, 2024 | 08:26 PM
GTS Bruce's Avatar
GTS Bruce
Too stiff for anything other than a perfectly smooth road.
Old Feb 16, 2024 | 08:34 PM
turbotuner20v's Avatar
turbotuner20v
Track mode is fine. PTM is what determines traction and stability. You can make Z mode mirror Track mode
Old Feb 16, 2024 | 09:02 PM
AzDave47's Avatar
AzDave47
Chevy recommends against track mode on the street as it is more likely to result in damaged wheels. Smooth roads will prevent that - if you have smooth roads where you live - lucky yoou.
Old Feb 16, 2024 | 10:33 PM
123sugey's Avatar
123sugey
Dig
MyMode is personalized. Set it up for how you want your car to feel all around
Old Feb 16, 2024 | 11:21 PM
Ragtop 99's Avatar
Ragtop 99
As mentioned above, setting the suspension in track mode increase the risk of wheel damage. I drive in sport and the car handles nicely.
As for the engine, once it is broken-in there is no harm in leaving the shift pattern in track. The negative side effects will be your MPG will go from bad to awful. You'll also change your oil a little more frequently as RPM is a major determinant in the oil life algorithm. Maybe if you put a ton of miles on the car, the engine will need a rebuild sooner. That's not an issue for most corvette owners.
Old Feb 17, 2024 | 04:00 PM
Gang Green's Avatar
Gang Green
Its a Z06 for crying out loud - Its purpose built for the track - Keep it in track mode if that's what makes you happy - The only you'll hurt is other peoples feelings! Enjoy the car to the fullest - you wont break it! LOL
Old Feb 18, 2024 | 08:19 AM
NakedDave's Avatar
NakedDave
No issues with using it on the street, other than some speeding tickets, loose fillings from the tight suspension and a **** eating grin as you love it!
Old Feb 18, 2024 | 09:32 AM
See Ate's Avatar
See Ate
There's no advantage on the street. Just a harsh ride and you're endangering your wheels. Just adjust your My and Z Modes for loud exhaust and stiffer steering and leave the suspension on sport or below.
To Track mode
