C8 Z06 Discussion General Z06 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
Engine light question
Old Mar 16, 2024 | 03:19 PM
RMB's Avatar
RMB
Default Engine light question
Picked up my C8 z06 a few weeks ago. I now have 175 miles and driving today the engine light went on and after letting the car sit for a period of time while doing something else the fault cleared.
Had anyone experienced this with the C8?
I am purchasing an update car analyzer and just want to know if this is a common issue with these vehicles. All other sensors working fine. The car was and continues to run with no other issues for the moment..
Thank you
Old Mar 16, 2024 | 08:28 PM
JABCAT's Avatar
JABCAT
Forum search feature or Google.
Old Mar 16, 2024 | 11:34 PM
EM Racer's Avatar
EM Racer
This is one of the reasons I am bringing my analyzer when I pick up mine at the museum at the end of April.
Old Mar 17, 2024 | 12:56 AM
range96's Avatar
range96
Thank you
You need to read the code for the CEL. No, CEL should not come on normally, something went wrong. It is cleared since it was a temporary failure. Yes, it is unfortunately a fairly common problem.
Old Mar 17, 2024 | 01:00 PM
minuteman71's Avatar
minuteman71
I took my car out of winter hibernation last weekend and as soon as I started it up it had the check engine light on. Drove it about 50 miles, still on. Bought an OBDLink MX+ OBD2, plugged it in and when I started the car light was gone and it wasn't showing any engine codes. It's not just a GM problem. My daily is a '23 MB S500 and it took a year for the dealer to finally fix an intermittent check engine light.
Old Mar 17, 2024 | 01:40 PM
Gang Green's Avatar
Gang Green
How common is this?
Old Mar 18, 2024 | 01:44 PM
Z51 John's Avatar
Z51 John
My car did the same thing fist ride of the season fifteen minutes into it CEL.
Pulled the codes.
ABS modular failure and Onstar comminucation problem.
Cleared the codes all set has not returned.
To Engine light question
