C8 Z06 Discussion General Z06 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
Can’t rev engine?
Old Jun 17, 2024 | 02:03 PM
mitch1965's Avatar
mitch1965
3rd Gear
Default Can’t rev engine?
Hi All,
Why aren’t I able to rev the engine in neutral? It revs great when you first start the engine, but doesn’t respond when pressing down the gas pedal and neutral. Is that right? Thanks
Old Jun 17, 2024 | 02:07 PM
jvp's Avatar
jvp
"Ask Tadge" Producer
I think it has to be in gear, foot on the brake, both paddles pulled back.
Old Jun 17, 2024 | 02:12 PM
noticket's Avatar
noticket
I believe you always have to pull in both paddle shifters if you want to rev above 3k. Doesn’t matter if in park or neutral.
Old Jun 17, 2024 | 02:45 PM
blackbirdws6's Avatar
blackbirdws6
If you want to rev all the way, put car in drive, pull both paddles in (D on the screen will flash) and have at it. Keep in mind if you let go of the paddles while revving it will basically dump the clutch and move forward.
Old Jun 17, 2024 | 03:36 PM
Ragtop 99's Avatar
Ragtop 99
This is it.
If you're in parking lot: Foot on brake (and keep it there, LOL). Put in gear. Pull Paddles. Step on the gas and entertain your friends. Hopefully the engine is up to temp.
To Can’t rev engine?
