C8 Z06 Discussion General Z06 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
Bolts on Engine builder plaque
Old Aug 9, 2024 | 06:29 PM
JJRIVS3's Avatar
JJRIVS3
Default Bolts on Engine builder plaque
I replaced the original plaque with a CF from AG motorsports and used the bolts provided. After driving, I noticed the left bolt missing. Somehow this became loose and disappeared. I replaced the remaining bolt with the originals and made sure both were pretty tight. On my next drive (pretty spirited) I returned home and the original right bolt was missing. What is happening here? Is the engine getting so hot it is melting the bolts, loosening them and they are falling out? It shouldn't have anything to do with the new plaque, so what is the cause? Also, does anyone have the part numbers for the original bolts so I can get replacements? I can try the lower mounts to see if they hold but need new bolts and I'm also concerned both will come off and the builder plaque will fall into the engine or be lost. Thanks.
Old Aug 9, 2024 | 07:00 PM
Rapid One's Avatar
Rapid One
Locktite needed
Old Aug 9, 2024 | 07:37 PM
Viperjoe's Avatar
Viperjoe
Veteran: National Guard
Loctite Blue.
Old Aug 9, 2024 | 07:46 PM
SMOKN C8's Avatar
SMOKN C8
I would go to my local True Value store and get bolts like the black one in your picture and apply VibraTite VC-3 Threadlocker
JJRIVS3's Avatar
JJRIVS3
Thanks. I forgot I had the blue- used on the jack pucks.
To Bolts on Engine builder plaque
