C8 Z06 Discussion General Z06 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
Does a CEL from cat delete affect performance?
Old Oct 6, 2024 | 06:49 PM
Gev's Avatar
Gev
Default Does a CEL from cat delete affect performance?
I'm not too worried about throwing CELs unless they somehow affect performance. Does anyone know?
Old Oct 6, 2024 | 10:09 PM
superramvette2's Avatar
superramvette2
No it does not.
Old Oct 7, 2024 | 08:04 AM
shopteacher's Avatar
shopteacher
Pro Mechanic
The purpose of the downstream (after cat) oxygen sensors is to measure cat efficiency and report that to the ECU. The ECU then adjusts fuel to keep the exhaust within the preprogrammed parameters. Although the removal of the catalytic converters may not directly set a trouble code the lack of ability to trim the fuel mixture very well might. On my Lingenfelter built C6Z they used high flow cats and this caused a DTC of inefficient catalytic converters. Using LS Edit or HP Tuners software we turned the downstream oxygen sensors off, making the ECU think all was OK. I guess what I am saying is to be safe reprogram the ECU.
To Does a CEL from cat delete affect performance?
