Have a 2023 HTC Stingray with excellent stereo, my 2025 Z06 stereo doesn't get HD and very poor sound quality. Has anyone else had this issue and found the solution for it??
Depending on the build month of your car, there might be an update to the infotainment system needed to get the HD stations to work, and there is also software that makes the EQ and speakers all work together better. So, see the dealer and advise them you have some type of issue, and even the Amp may be defective from the factory. That happen in alot of GM trucks in 2010.
have a 2023 htc stingray with excellent stereo, my 2025 z06 stereo doesn't get hd and very poor sound quality. Has anyone else had this issue and found the solution for it??
Turn off the f****** stereo and sound system and just simply listen to the engine and exhaust note with the windows cracked open.
C4 of Year Winner (performance mods) 2019
I've had 23 Stingray (3LT), 24 Z06 (2LZ) and 25 ERay(2LZ), all HTCs. The stereo has sounded exactly the same in all of them, but then I always using streaming services and never listen to "radio".
I had to turn down the treble like 4 notches to make it tolerable. Bose is garbage. Coming from a B&O on my 2019 TTRS, its embarassingly rough sounding. Treble till your ears bleed, no midbass, muddy bottoms.
I guess it depends on what you compare it to. My 992 GTS Bose is terrible compared to the vette.
I find the audio system in my 2025, 3LZ coupe to be quite satisfactory. In fact it’s considerably better than the optional premium audio system that was in my F8.
The C8 system is actually pretty good for a stock system, but like you found, you do need to tweak it. The biggest thing I've found is turning off the damn AudioPilot, which screws with the sound a lot (especially if you have an HTC).
Of the 4 Ferrari's I've owned none of them had a sound system to write home about. My 2023 HTC Stingray 3LS has a very good sound, wish I could say that about my 2025 Z06 LZ3............
