What you can do initially record the new track. Then take the SD Card out. Put it into your computer and rename the file. Then the next time you go to a new track you can save the new track and do it all over again. By doing this I have a ton of tracks I have saved. Once you do this your PDR will show all the save tracks you have so you don't have to continue recording track maps if you have already saved and renamed the track.
Originally Posted by jswatek
You can only save 1 Otherwise you have to save the tracks on your computer. They covered this at Ron Fellows. Have you already saved one?
Ya, at RF they didn't actually cover this, they just said "save" it, but never showed the process actually. I dont get why there isn't a "save track" option? I found it on a youtube video, 4 year old video, "Save Track, and even though I have 24 Z06 with PDR, I don't have that option, so why not? Did they remove this feature?
They just couldn't add a simple "save" button on the PDR? wow. Ok, so what file do you actually rename? If I track for the day, say 5 sessions, what should I see what what file do I need to rename? And any specific extension?
^^^This^^^ It is a PITA but you can save an unlimited number of tracks if you rename it before going to a new one.
Do you rename just of one of the track sessions or the master folder?
I'll post a screen shot later. If I recall correctly, there should be a folder on the SD card that is named Tracks. In that folder, there should be a file that is named custom. Rename that file to the track (or name you want to call it). It should then show on the PDR under available tracks.
All good, figured it out, had to download app and now it’s saved. Thx
