C8 Z06 Discussion General Z06 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
Torque specifications for alignment work?
Old Feb 22, 2025 | 07:48 PM
AVETTE's Avatar
AVETTE
Cruise-In II Veteran
Cruise-In III Veteran
Default Torque specifications for alignment work?
Just wondering if anyone has the proper torque specifications you would need when doing an alignment for the front and rear of the car, thanks. I want to make sure things are torqued to proper specs
Old Feb 22, 2025 | 07:58 PM
subydude's Avatar
subydude
It's 111 ft/lbs plus 90-105 degrees on the eccentrics. Both myself and the guy who owned the rack were surprised. He owns one of the fancy torque wrenches that has an angle side. By the time it hit 90 degrees after 111 ft/lbs it was between 190ft/lbs and 220 ft/lbs of total torque on the nuts.
Old Feb 22, 2025 | 07:59 PM
AVETTE's Avatar
AVETTE
Thank you
Old Feb 23, 2025 | 03:20 AM
AVETTE's Avatar
AVETTE
Default Someone else
Quoted 70 ft lbs… did you get the 111 fr lbs from the service manual?
Old Feb 23, 2025 | 10:04 AM
mikegr's Avatar
mikegr
Service manual is 111 ft lbs plus 90 degrees
Tie rods are 55 ft lbs front and 74 ft lbs rear
Old Feb 23, 2025 | 08:16 PM
AVETTE's Avatar
AVETTE
Default Thanks a million
Thank you!
Old Feb 23, 2025 | 08:19 PM
AVETTE's Avatar
AVETTE
Default Any info from service manual on rear caster
Any info on rear caster
Old Feb 24, 2025 | 06:09 AM
mikegr's Avatar
mikegr
what kind of info? Should be set to 0
Old Feb 24, 2025 | 09:04 AM
Mitchell_B's Avatar
Mitchell_B
Here
Old Feb 24, 2025 | 10:04 AM
jswatek's Avatar
jswatek
Originally Posted by Mitchell_B
Here
This stuff is super helpful to me. Thank you!
There should be a sticky with these various PDF's for future reference.
Old Feb 24, 2025 | 10:25 AM
AVETTE's Avatar
AVETTE
Default Thank you all!!
Thanks to all
Old Feb 24, 2025 | 10:31 AM
mikegr's Avatar
mikegr
Think I was able to downlaod my manual for like $15, it is PDF format with index for searching, gives these identical details and images. Might be worth trying to find one if doing a lot of work.
Old Feb 24, 2025 | 11:29 AM
Factoid's Avatar
Factoid
I got mine on eBay. Once you pay, he sends a link.
Old Feb 27, 2025 | 06:22 AM
spearfish25's Avatar
spearfish25
Which eBay service manual did you guys buy?
Old Feb 28, 2025 | 09:58 AM
jswatek's Avatar
jswatek
I will pursue getting a service manual online. In the meantime, can someone give me the torque spec for the steering wheel nut? There is already a loose nut behind the wheel!
Old Feb 28, 2025 | 10:28 AM
mikegr's Avatar
mikegr
33 ft lbs
Old Feb 28, 2025 | 01:45 PM
jswatek's Avatar
jswatek
Originally Posted by mikegr
33 ft lbs
Thank you Mike! That bolt felt like way more torque than 33 lb/ft. Good information to have. I would have guessed 50-60.
Old Feb 28, 2025 | 01:53 PM
mikegr's Avatar
mikegr
No problem, threads look good?
To Torque specifications for alignment work?
