C8 Z06 Discussion General Z06 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
Trunk issue
Old Mar 1, 2025 | 07:42 AM
mjf5012's Avatar
mjf5012
Default Trunk issue
Hi everyone. Was the issue with the trunk starting in 2023 fixed where the only way to open if the solenoid failed is to cut a hole in the trunk lid?
Old Mar 1, 2025 | 08:16 AM
Phil1098's Avatar
Phil1098
2023 is the first year they removed the emergency lock cylinder on all C8s. Pretty sure they have figured out you can remove the wheel liner on the passenger side and snake around to get it open without cutting a hole in the lid.
Old Mar 1, 2025 | 01:18 PM
AzDave47's Avatar
AzDave47
Run your own safety wire from the inside trunk pull to the right rear corner of the trunk deck lid that you can fish out with a simple pull tool. That was posted on this forum back in early 2023?
Old Mar 1, 2025 | 11:30 PM
mjf5012's Avatar
mjf5012
Thanks for the replies. I've seen the solutions people have posted in the forums. I just wasn't sure if GM fixed the issue on its own. I had a 2023 Stingray and I'm thinking about getting a Z06.
Old Mar 1, 2025 | 11:52 PM
AzDave47's Avatar
AzDave47
The Home fix is much more convenient for the customer, given how GM cheap'd out on the cylinder lock. My C6z had that trunk solenoid fail and using the key was just a minor inconvenience. GM doesn't care how much they inconvenience their customers.
Old Mar 5, 2025 | 03:43 PM
Red Mist Rulz's Avatar
Red Mist Rulz
GM has issued new guidance to dealers on how to access the trunk in the event the solenoid fails that no longer call for drilling a hole. There were two difference approaches provide. I don't remember the specifics, but neither required damaging the vehicle. That hole drilling thing was apparently meant for a very specific failure, and GM later said it should never have gone out as a TSB.
Old Mar 5, 2025 | 04:04 PM
mjf5012's Avatar
mjf5012
That's great to know. Thank you.
Old Feb 24, 2026 | 02:50 PM
adriankapl's Avatar
adriankapl
Does anyone know what the solution is. My 2025 z06 has the issue
Old Feb 25, 2026 | 06:49 AM
Doctor Mark's Avatar
Doctor Mark
Since your car is a 2025, why not the dealer address the issue. Not as convenient as DIY but it is under warranty.
Old Feb 25, 2026 | 02:43 PM
adriankapl's Avatar
adriankapl
Don’t trust the dealers around my area. If I have to I will go.
To Trunk issue
