C8 Z06 Discussion General Z06 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
2000 performance change ?
Old Mar 12, 2025 | 08:28 AM
B-52's Avatar
B-52
Default 2000 performance change ?
When my 2024 Z06 passed 2000 miles I almost immediately noticed a performance change. Throttle response and torque increased. Does anyone know if GM had an ECU limitation that was removed at 2000 miles?
yes I am aware of the 1500 mile limitation , etc . and been driving sports cars for many years. I thought it was my imagination, but I also might just be nuts.
Old Mar 12, 2025 | 10:20 AM
Performance nut's Avatar
Performance nut
I'm at 1950, I'll see if I notice anything
Old Mar 12, 2025 | 10:23 AM
Cjunkie's Avatar
Cjunkie
Placebo effect
Old Mar 12, 2025 | 11:32 AM
AzDave47's Avatar
AzDave47
Torque was limited in 1st and 2nd gear up to 500 miles. After that, it is all just the drive train wearing in fully.
Old Mar 12, 2025 | 11:43 AM
lgodom's Avatar
lgodom
Maybe the transition away from winter blend gas is occurring in your area. Winter blend gas has lower energy output and the Z06 may be more sensitive to the switch.
Old Mar 12, 2025 | 01:15 PM
range96's Avatar
range96
I thought summer formulation of gas is between June 1 and September 15 nation wide.
Old Mar 12, 2025 | 05:30 PM
Bald Guy's Avatar
Bald Guy
I was thinking and experiencing similar... But then I realized that it must've been me having fresh energy and mindset after taking a nap and jumping into the Z. : )
Old Mar 15, 2025 | 03:40 PM
B-52's Avatar
B-52
If anyone cares . Well my butt dyno was working but not so much my simple DIY problem solving .
I had installed ( and very much like ) a Solar throttle controller. The control head is in my center console. For street driving I like Sport 0 on the controller. At some point I must inadvertently caused it to go to Sport 3 .
Issue resolved
Old Mar 15, 2025 | 03:45 PM
Misty C8 Z06's Avatar
Misty C8 Z06
Issue resolved
It happens. Glad you got it figured out.
Old Mar 15, 2025 | 05:15 PM
Factoid's Avatar
Factoid
I disconnected the wired controller and only use the app. Keeps this from happening and allows me to lock the throttle without a local controller.
To 2000 performance change ?
