PTM Question
PTM DRY: ESC is on, engine power is slightly reduced.
PTM SPORT 1: ESC is on, and additional power is available.
PTM SPORT 2: ESC is off, same engine power as PTM SPORT 1
PTM RACE: ESC is off and additional power is available for maximum cornering speed.
PTM is not on when you simply choose Track or Z modes. You would need to then activate PTM by pressing the traction control button twice. In theory, if you were going for your very best lap times on a track, choosing the appropriate PTM mode for the conditions and driver skill will yield a faster lap time than not using PTM. This is heavily dependent on driver skill.
So what setting is the car in when it is in sport or tour mode? Is the ESC on and is the PTC off?
Or asked differently, How does Sport mode compare to Z mode with similar setting and PTC set to Wet! As you can see, I need a little help here understanding how all of this works.
So how does the standard Track TC/ESC compare to Track PTM Wet?
Does anyone know which is more conservative?
The difference between Traction Control (TC) and Performance Traction Management is primarily two things (this info mostly from an Ask Tadge you can find).
First, PTM assumes a track surface -- in other words, unless in wet mode, a dry, smooth, good traction surface. TC assumes it doesn't know what kind of surface you are on -- which plays into the biggest difference;
PTM is mostly predictive. It determines based on a bunch of information (steering angle, throttle position, yaw sensors, etc...) how much power to send to the wheels with the plan being it will send as much as it can without you losing traction -- this is where knowing what the surface is helps, because the assumptions work better.
Traction control is mostly reactive. It doesn't do anything until it senses wheel spin, and which point it dials back power (and even adds brake if need be) until it senses traction again. This is safest on the street where it might be wet, gravel, snow, who knows, but will slow a good driver down on the track.
Stability control is similar in PTM modes and non PTM modes, but has varying degrees of intervention depending upon the drive mode or PTM mode. ESC is off in the last two PTM modes (Sport 2 and Race or Race 1 and Race 2 depending upon year of car).
So, to the original question, PTM wet mode will be pretty aggresive at limiting power and more conservative ESC compared to Track non-PTM ESC's. However, in snow or something where it is hard to get traction in a straight line, standard non-PTM may help better because. Weather mode compared to Wet PTM is a different story....
In any drive mode (weather, tour, sport, track) you have both traction control and stability control active. It’s more assertive on doing its job in weather than in track.
Once in Z mode or Track mode, you can enter PTM modes. Wet, Dry, and Sport all have both traction control and stability control active. It’s dialed back as you move to Sport. Race 1 and 2 have no stability control active. Slide the car and you better catch it. They just let you put power down (and more of it) without spinning the tires as readily as you would without any traction control. The Pro drivers are faster with it all turned off. You can turn it all off in any drive mode if you push and hold the TC button down for 5-10 seconds.
