C8 Z06 Discussion General Z06 Corvette Discussion, Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored By:
Sponsored By: Wheel Designers
Finally!
Old Jun 12, 2025 | 07:33 PM
Patientz06's Avatar
Patientz06
Default Finally!
Here she is from OK to CA.
Had her for a couple days. Drove her once so far. What a beast.
I know the street break in is 500miles.
can I stil put it in track mode?
can I use paddles ?
Old Jun 12, 2025 | 07:52 PM
patton's Avatar
patton
St. Jude Donor '09
can I use paddles ?
i would go with what the owners manual says plus you have to get broken in to the car
Old Jun 13, 2025 | 01:50 AM
Bald Guy's Avatar
Bald Guy
That's a nice color, and looks like you snatched up a rapid blue for the final year. Nice homes back there as well.
Agreed with @one more on keeping a close eye on your manual and taking it easy for the initial steps.
Old Jun 13, 2025 | 03:01 AM
Patientz06's Avatar
Patientz06
yeah I looked didn’t see anything about putting it in track mode or using paddles
Old Jun 13, 2025 | 05:15 AM
Bald Guy's Avatar
Bald Guy
I wouldn't recommend it at this time because it might tempt you to hang on to the gears a little too long or you might get tempted to really test out the beast here and there.
I personally put it into track mode and started using the paddles right from the get-go and I still do the same thing every single time even right now. I would rather you be safe than sorry, and that's why I didn't recommend you drive the way I did initially because most would probably not agree with it anyway. It's not totally to the book and politically accurate. Long story short, be cautious and sensitive to the car since I know it's your baby.
Old Jun 13, 2025 | 05:28 AM
BuckySti's Avatar
BuckySti
On my ERay, the computer set redline to a lower value, and wouldn’t let you over rev the engine prior to 500 miles. I even have a video of the display resetting itself after hitting 500 miles. Does the Z06 not do the same?
Old Jun 13, 2025 | 05:36 AM
jvp's Avatar
jvp
"Ask Tadge" Producer
No. The temporary lowered redline in the C8s and any other GM product (including the ERay) is visual only, to discourage you from revving past that mark. You can still do it, and you could have with the ERay if you'd put it in manual. The only thing that stops the engine from revving past a certain point is the actual rev limiter and that's hard set for each different type of engine. It's 100-200RPM above the actual redline.
For the OP: drive it in any mode you want and go ahead and use the paddles. Just keep an eye on that visual redline as a reminder when to shift. Your car will be fine.
Old Jun 13, 2025 | 06:53 AM
BuckySti's Avatar
BuckySti
Thank you for the clarification. So they tricked me , which isn’t a bad thing.
Old Jun 13, 2025 | 08:06 AM
HysteriaC8Z's Avatar
HysteriaC8Z
Congrats on the new ride. Looks great!
Old Jun 13, 2025 | 09:48 AM
skylolow's Avatar
skylolow
You're fine using the paddles. They just don't want you to go over 4Kish in RPM's and don't want you to downshift that push revs past 4K. Also they don't want you to labor the engine in to high of gear for the speed.
Old Jun 13, 2025 | 01:20 PM
gtrguy's Avatar
gtrguy
Thought I read should avoid track mode for 500 miles for chassis breaking period too? Manual mode ok as long as don't go above 4k or so. Definitely avoid cruise control though. And wouldn't launch it until 1500 miles to be safe.
Old Jun 13, 2025 | 02:21 PM
HRDTOPC54FUN's Avatar
HRDTOPC54FUN
Congrats. Great color choice. As others have said just drive reasonably for the first 500. Goes by pretty quick.
Old Jun 14, 2025 | 06:10 PM
DeltaT's Avatar
DeltaT
CF Community Team
Sweet ride, congrats! Are you in NorCal? There is a growing number of Z06 owners up here.
Old Jun 15, 2025 | 10:52 AM
Patientz06's Avatar
Patientz06
yessir I am in NorCal. Yeah definitely seeing more Zs around here
thanks everyone! Much appreciated!
To Finally!
